  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
cheers MJ im stoked but theres more in it, Eug its called stalling it up, bring the revs up with ur left foot on the brake, though my car has a very low stall rate compared to most autos so the power kicks in at like 1500rpm, if i get a stall convertor i can shift that point to most likely 2500-2800rpm which will make for a much much better launch.
no, no more wheel spin, just means the auto starts off higher in the revs so its making more power, kinda hard to explain but yeah trying to find some wider rubber for the rear is definately on the cards.
Uhm.. pretty crap. Too much wheel spin. But everyone seemed to be getting it.
Best I did was a 13.9 @102mph. I've got the mph, just need to get the good launch.  :P And yes I will blame my crap driving :D
how are your rear tyres holding up....maybe you could blame them :D
seriously though...MJ did a similar time last T&T and he has similar mods I think AND brand new Azeni's
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
