  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Lap Dances and beer come your way soon after... at least it did for me
ohhh niiice.. did u get that JL?? :P
eug, wider tyres and dont out drive the limits of what you have
I was taking it easy last night, and was still skidding... figure if I'm gunna do more of these
runs then I'm gunna have to get rid of the stockos.
did u really find em gettin greasy James?
jason i found the a539s tended to get real greasy when you heated them up
I thought they were pretty good. I used my last set for 35 laps around Q.R. and they did pretty well. Looked a little worse for wear afterwards though as to be expected under those conditions. Great in the wet, and I beat Paul by 2 sec at the last time trial (forget witches hat). Can't be too bad.
Don't how much they would be in your size Eugene.
mmmm i still feel sick aye, this isnt good, i fake getting sick alot to get out of schoo, but i cant remember the last time i actually was sick, and my left nut still hurts, i think ive done something serious to him this time....
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
