  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
since I fitted the 3" dump pipe, when I go full throttle to the redline I get a pop/miss between about 5000rpm and 6000rpm, then it smoothes out and revs freely to the redline.
If I use half to 3/4 throttle it revs smoothly to redline without any problems.
Any idea what might be causing this and what I need to do to resolve?
That would be boost cut (or excessive air flow cut as it is properly known...)
Your AFM is maxing out at those revs...
Few solutions... Lean the SAFC out at those revs... Fuel cut defender... Z32 AFM... Less boost... 0.8mm gap on the plugs may help but I doubt it in this case...
hmmm....OK....will have a look at the plugs first, but the previous owner reckons they are iridiums and gapped to 0.7
If that doesn't help I'll clean the AFM coz it looks pretty dirty (what about removing the mesh?....you think that would help?)
THEN I will try lowering the boost a tad, and if all else fails have the SAFC retuned on a dyno by someone who knows what they are doing.
Thanks for the info Adrian
well thats what my problem was, couple of solutions for different problems there :D
Yeah, thanks....I think I'll change the plugs to some plain old NGK coppers anyway and see if that helps.
Has anyone tried the electrical tape on the coil packs trick I read in a thread somewhere which is supposed to resolve some coil issues?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
