Thanks, and nope. No money, no life, no freinds and waiting for cops to come round which they just did now, only 27 hours late to do a report on an attempted break in while I was out of town :)
That's no good :rant:
I hope you were able to spend the day with your kids at least.... that would be enough for me :D
Only an attempted breakin? I am surprised the cops bothered showing up at all.
Thought they would have some Evil Import Cars to defect
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Ben: No.. I meant that he can call up and report that "someone" was doing skids
outside his house... and since the police are "convieniently" there... they might
as well check out his ferked screen doors.
John: drifting cats?? hahaha.. yeh record it one day... :rant:
I get the kids next weekend, I went camping by myself, had some stuff to sort out, so I went somewhere I didnt even know about, with no mob phone and just relaxed and sorted myself out, was a great weekend untill I got home :rant:
Yeah I am still trying to figure out why they didnt try to defect my stripes as they walked past my parked car :)
Yeah I have to get away and be by myself to regenerate sometimes.
I get pulled in so many directions at times, It is the only way that I can recharge the batteries.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
