  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
This where you need to go to if you have what it takes Eug
http://www.au.mensa.org/
I have been a member for 11 years now :P
are you for real that you're a member chris??? You seem far too socially functional to be a member of Mensa. Do you know Anna VanHoof????
I reckon you put Nex and Strutto in a closed room and they could fix all the worlds problems :P after the strippers leave though :)
Yes for real I am a member, my father is too, I will show you my member card if you like :P
The majority of them most certainly are a strange lot, hence why I do not participate in any of the outings or events they organise.
I occasionally join in the chat forums if it is something that interests me at the time.
Anna Van Hoof, I do not know, although the name does sound familiar, I do seem to recall an "Anna Van Hoof" being responsible for a spate of "Virgin Mary" sightings in the mid 1950's on the Sub Continent
Hey matt
how's the hand ?
Hope it wasn't the "important one" if you know what I mean :P
Its has healed up really well. My index finger is a white/yellow color and impossible to move... Swollen a bit as well. It will look very ordinary when it all dies and falls out of my finger....
I sign my name right and tuck myself in at night with the left :) bahahaha
afternoon
cyrus you left the laptop unlocked :P
Yeah I know, remembered when I got here and couldnt be bothered locking from here, also hoped you'd make it back before Bean, so all is good, you know what to do if they get home right, :)
well there home now but i got the door shut
bababhHB hba haHA hAHA h ah Ah aH a soon you'll have Amanda bang on the door, "What did you do today?" BAba bah Ah ah ah AhA hah aH aH ahaaaaa!
Ah well thank god for doors eh! :P
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
