  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hi James, meh still sore. I have to ice it every day after work as it swells quite a bit. At least I can walk around without a limp now.
Don't know whether I should ask...... but, how is your car situation coming along?
Incidently a description of me :)
Haha..
Sorry I've just come to the computer. I found this funny. I giggled :rofl:
I've been cutting up paper for my invitations. I dont know how straight they are, I guess I'll find out when I go to put them together :confused:
Makes you think when others cars are stolen. I wouldnt own a Skyline if it were to be left in a driveway or on the street.
Same the only car I leave outside in confidence is the Gemini Van. Dirty, smelly thing it is. Bit scary when you here them go, especially when it is so close to home.
you know the funny thing though I have seen one of these old gem's roof down burnt out the other day with motor g/box every thing still in it
Yeah, I had a guy hit me up about the Gemini once doing a sub-division at sumner park, said it was a yellow van just like mine and had been stolen that night, seriously, you would have to be desperate to grab mine, it is sooooo dusty inside you have to wipe the dash just to see how fast you are going.
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
