  • 1 year later...
sorry to bump an old topic....
does anyone else use a Quaife front diff i their GTR? i want it for street use, good strength, a bit of everything, a trip to the drags and the odd circuit day.
I talked to Ash (31nismoid) he seemed happy with the nismo front diff, The quaife centre i can get in australia, if i go cusco or nismo i will most likely inport it.
thoughts??
"Gav" & "R32-TT" (i think thats wrong lol) - both WA users they have Quaife fronts.
I believe Gav is around at the moment and not away for work, drop him a PM :thumbsup:
As i said in my PM's, it wasn't just the front diff. Also had a modified transfer case & rear diff - its the overall that makes a difference as when i just had a front it was good, after the rear was done it was sensational.
Ive got a couple of customers that we've installed quaife enters for.
One has a factory transfer case, nismo shimmed rear diff and quaife front with 4:3 ratios.
It's subtle in the car park but works well on the track (track only GTR)
Another has a quaife front, nismo rear, modified transfer and actuator, seq hollinger and 3:5 ratios.
It's a bullet of a car and the gearbox makes it a pig, the diff has been terrific.
Good question, I can get one for 1699 delivered from just jap. Anyone know a better dealer?
The quaif diff sounds awsome for street and circuit work, anyone know what it wo be like launching at the drags?
I got mine from SVS in the UK
[email protected]
The blokes name is Tim. Champion of a guy. It cost me about $1100 but then i got raped by customs.
Another option is [email protected]
Cant remember the blokes name.
Can't comment on how it drives but give us a few weeks and I will. Matty and Gav from WA swear by them!
Having driven a mates GTR with a similar setup to mine recently (he didn't have a front diff or transfer mods, but did have a rear diff) - the car was very very tail happy out of corners as if it were RWD... Where mine would put all the power down and drag you out of a corner with only a mild squirm in the rear at best.
Hard to say if it's just one part, it's certainly the overall combination of the 3 drivetrain parts add up to a noticeable difference irrespective of which front diff you go with.
But given how my mates GTR drove, I'd certainly be thinking about a front diff as well. Honestly if i had my time again the first mods to a GTR aside from turbos/injectors/ECU - would be to do the diffs etc. Highly rate it as a course to take
Diff arrived, Palmside were good to deal with, Bought for less than 1k delivered in the end, bargain in my books.
pics
and all new bearings to install
BBQ, oil and liquid nitrogen used to get the bearings on and cups in the diff
  • 1 year later...
What advantages would a Quaife have over other front diffs like , Nismo, ATS and OS Giken.
I have Nismo 2-way LSD at the back, would it be better to get a Nismo at the front or mix it with the Quaife at the front.
I chose a quaife for the front of my GTR and a nismo clutch pack upgrade for the rear.
Different tech to all the others, the result is a better design for the steering and drive end. I'm sure the nismo would be fine if bedded in correctly, i have driven a GTR with an ats front diff, quiet but felt notch-y. I havn't mush experience with an OS front, but I would imagine they would be great on a drag car.
Ford used them as oe in some of the performance focus models, so can't be a bad thing.
J.
Edited by XRATED
'locking up' generally is a term used to describe a point at which the diff positively engages a torque bias.... this may be a percentage or a full lock up depending on the diff and how it's set. the term is mostly used with clutch style lsd's. An example would be an aggressive kazz rear diff in an s13, at slow speeds it will 'lock up' on a short turning radius and bang the cv's/tyres (essentially the same as a welded diff).
this is why I chose the Quaife.
http://quaife.co.uk/quaife-products/quaife-differential/
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
