$3650 each seat WOW!!!
Imagine the cost of rebuilding an entire r32 gtr from scratch with all OEM parts...scales would have to be over 300k lol
And it only cost $110,000 AUS to buy new...
Hi john,
I did what bob did and chased a good passsenger side seat and used it to cover the drivers seat.You can peal off the cover if your careful and patient.
a motortrimmer will be able to stich the side where the mechanism usually sits
Another option is watch import monster.I managed to score a perfect back assembly for $75
And if your real lucky like i was i managed to purchase drivers and passenger seats that had been swapped out for recaros early on,stored in garage and sold seperatley many years later when after car had been sold.
the two seats cost $1500 del to my door from japan
Hi john,
just had alook at import monster, you might be in luck
look under car parts,seats and use bnr32 as the model of seat your looking for.
two days before auction ends and there are no bids.Current price is 1 yen and it's drivers side also
Good luck
My hicas light comes on randomly now and stayon when cold. But every left turn she lights up.
Any ideas?
And after 10 years without having Hicas issues on this car I thought I got lucky!!
Edited by gtr fan
When I had my jdm gtr and removed the engine and box, I had to bleed the hicas system which runs thru a set of procedures...no big deal but it is a bit of a pain.
Good that a simple top up fixed your issue :)
I kicked the old girl in the guts the other day, first start in 3 months, started easy and straight into a smooth idle. I picked up a pair of seats pretty cheap acouple of years ago, not sure how hard a good set of second handies are to find now, some patient, consistant searching may pay off.
Ok guys, any one with their legal hats or registered motor vehicle valuation caps on have any idea about getting a value for legal purposes of my ADM BNR32, inbox replies please rather than pollution of this forum. I believe the value I have been given to be a little on the low side.........................
Cheers in advance Alex
Hi Alex,
I've just deleted my original post as the penny just dropped on the background to your car.
Could you please refresh our memory with the mileage?
What general condition would you give the car out of 10?
Thanks,
Bob.
  • 3 weeks later...
Anyone know where I can buy a replacement high mount stop light? Was the one in the ADM ever standard on the imports?
I just put in a child seat for my daughter and got her to sit in it and try it out and she just reached up and ripped on the case which broke it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
