I just tried some rims last night on mine with factory suspension and these were the results.
19x8.5 + 33 front was flush with guard, 19x9.5 +24 rear stuck out about 10mm.
Wheels are Volk GT-V's
And 19's still look small on these cars.
So for minimal work to fit on a stock car (ride height, camber and guards) 9.5 +35 would be a pretty safe bet imo.
Even with minimal lowering; the 19x9.5 +24 would be essentially flush with the guards, It makes a huge difference.
19's don't necessarily look small; but if you get the sidewall height wrong; the guards will swallow up even 20's and make them look tiny.
Have you thought about increasing the rolling diameter, and going up in aspect ratio to fill the guards?
The speedo reads miles under anyway (around 10%), the extra rolling diameter doesn't blunt performance by much, and you'll vastly improve ride in the process.
Just a thought.
Wheels look great!
Think the tyres pictured are only 235/35 so they are way too small. Not my wheels - just tried and tested as they had too much damage for my liking.
Personally I would have liked to go to a 245/45 which is a little larger rolling diameter than stock by 3.39% (245/40 is same as factory).
I use www.willtheyfit.com by the way to work this out.
Personally I don't want to lower the car as it's nice to drive places without having to worry about front bumper and exhaust etc scraping on everything.
My S14 is my lowered car
Hope this info is helpful to others out there anyway.
  • 10 months later...
@tony200 that's actually a big help,I'm in the process of buying wheels at the moment .
I have been searching through these forums and the net but a lot of conflicting offsets,it's nice to see some top down pics.looks like 19x9.5+22 is perfect for stock bodied m35 on the front ,looks like the rear should be +35,but what about axis and arx?
I have an axis and some say 19x9.5+22 is perfect on the front but it's not if I want the look the front of yours has in that pic .
Also the rears some are running 10.5 wide with stock springs and don't scrub while others say they scrub.
If someone has an axis or arx could I please get some top down picks of flush offsets please.
4 hours ago, Leroy Peterson said:
Should be fine depending on tyres. What's your budget?
Not a lot, only looking second hand.
Currently got the stock 17x7 rims which are nice, but they just don't fill out the guards and look too narrow from behind especially on the rear.
I would consider getting slightly lower springs, which might help the look too
its a bit hard to find offsets which suit our larger Nissans, but theres always something on Yahoo Auctions.
heres a handy cheat sheet for searching Yahoo http://www.mlracing.co.nz/yahoocheatsheet
with 5mins of searching found these, might not be what you're after but there are bargains out there
https://page.auctions.yahoo.co.jp/jp/auction/n223819128
https://page.auctions.yahoo.co.jp/jp/auction/n223819124
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
