Hey All
I bought another spare turbo for my R33 Gts25t but have discovered some differences. Can anyone help me in telling me what it is off? Main differences:
Spare one I bought is only oil cooled and does not have water feeds.
On Turbine side there seems to be more blades and the turbine hole is bigger
Compressor blade looks very different to.
Pictures are below.
Standard / Current Turbo Side On
Standard / Current Turbo Rear
Standard / Current Turbo Front
New Turbo Side On
New Turbo Rear
New Turbo Front
I look forward to hearing from you guys and your help.
Cheers
Kailaas
https://www.sau.com.au/forums/topic/343930-whats-this-turbo-off/
it is water cooled
looks like an r33 turbo to me. and this looks like the coolant feed.
both the compressor and the exhaust housings point towards an r33 turbo
if the compressor turbine is made of steel then it's from series 1 R33, if it's nylon then its S2 R33
Edited by chiksluvit
Thanks for the help. Will look for the numbers on the housings and post back. Does this mean the the turbine wheel is more likely to be steel than ceramic? Is there any way of finding out?
Will have a look in the morning for the numbers and try the magnet thing. Lol nah im only looking at running like 15 psi max. still a stock block with just basic mods and only got a safc 2. Hopefully it aint to laggy or anything like that.Being that its only oil cooled whats the best way to ditch the water lines? Join them together or just remove and block off?
weld the holes on the bolts and screw them into the block without the pipes, problem solved =]
to me, it looks like a highflowed nissan turbo cause those wheels definately aint standard, especially the exhaust wheel..its HUGE
Edited by XxNinjaxX
Without injectors & AFM that turbo is largely a fruitless upgrade.
In fact pretty much every turbo is, you need supporting mods for anything other than the factory turbo
Thanks. Yup I am looking into afm and injector upgrades. I have seen on these forums from the dyno results page of people running highflow turbos on safc's etc so would be interesting to hear from them. But am definatly aware and looking into investing in some injectors, afm and most probably a nistune in the near future.
Will post up numbers on the covers tonight when I get home. For those who want to know current engine mods are:
Full 3 inch Exhaust from turbo.
Apexi Pod Filter
Front Mount Intercooler
SplitFire Coil Packs
Nismo In Tank Fuel Pump
Safc 2
RSM
Aftermarket Light Flywheel
Excedy 5 puk clutch
12 Psi of boost
Stock Turbo
38mm External Wastegate
Am Looking at making around 230kw at the wheels or so.
I have read and been told i should be fine with stock injectors and might just get away with the stock afm. Am still looking into gettins a full aftermarket ecu to gain full benifts even though some have shown that they have run highflow turbos on safc 2.
Edited by K-LESS
Compressor Housing has 45v2 on it and I can not read the turbine housing. I think it might be OP6. Tried to look for a badge of some sort to see what internals were used but could not see anything either.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
