nice looking car man, with the oil, its probably just the gauge playing up
when the car is cold and the oil is thicker, it gets up to about 4 or 6 on the oil pressure guage. then it drops back idleing when warm.
watch my walk around video of my burgundy R32 GT-R. also, if you could let me know whether your gtr's oil pressure does the same as mine that would be sweet.
Tidy car mate, nice work.
and the fuel consumption is pretty much on the money, unless you were babying it
clean car congrats on purchase...
re the oil pressure, ive herd its common for the sensor to be wayy off but might be a good idea to change the oil pressure sender. mines never drops below 2.5kg even on a hot summers day
got an engine bay pic? :D
yeah. i'll post it here now.
very standard. dyno sheet of 180kw at all four. runs so nice though.
very nice and clean mate !
any mods done to it? aftermarket exhaust, boost controller etc ?
it came with an a4 binder full of receipts of EVERYTHING done to the car for the last 6 or so years...
rebuilt high flowed standard turbos 24000 k's ago. full 3 inch exhaust and 4 inch tip (still got a cat and a muffler so it's quiet but a nice note) 4wd controller and a 4wd 2wd switch. and uhhhhhh. can't think what else :S
yeah; neat car, good onya. re oil; first,I would get the oil pressure checked, if the pump is ok then hunt down and replace the faulty gauge/sensor. take out the guesswork, could save you plenty of $$! prob is the gauge/sensor, but not wise to gamble with oil pressure. regards
    • I had issues with my car today after removing the rear bumper. The headlights aren't working when turning the stalk but high beams are working and the rear tail light where the reverse camera is wired up won't turn on when the stalk is activated, but the reverse camera, tail light indicator and brake light all seem to work. I checked the fuses they aren't blown. I think the reverse camera could have possibly gotten pinched but shouldn't be as there is a decent amount of room. I did use the lights and loom for the license plate from the new bumper but also tested the old one in case but made no difference. This isn't for a skyline also. Any ideas what it could be? It was working when I drove I'm pretty sure, then on my return home I noticed my headlights weren't working.
    • IMG_6023.mov   In motion 🤙
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
