Or maybe just harden the f**k up.
It's not netball, the racing is actually supposed to be the pinnacle of contests ( and challenges)
Basically, nothing good as come though regulation changes for about 20 years Except the reversal back to non grooved slick tyres.
Every time the FIA have a chance to really fix the sport they f**k it up.
God I'm such a whinger.
Not whinging, you're just thinking along the same lines as many millions of f1 fans around the world.
Edited by Galois
I wonder how the world media would have reacted if a steward said "they penalised Hamilton because he was black....that's what Ali G says....I am just kidding".
They hit him with a powder puff anyway, 20 second penalty which cost him nothing.
Roy is spot on, if he said the track is tight and opportunities are rare as hens teeth. In both cases the drivers left the door ajar but closed it before I could complete my move.
He will be great to watch in Canada.
There's also 54 billion chickens in the world*
*[citation needed]
im tipping Canada will be an absolute cracker... overtaking will be making its comeback
I concur, Sir; Hopefully they've now crunched enough data on where to place the activation lines to ensure we get to see lots of ballsy braking zone battles
Haha, here we go, the thing I've noticed about commentary is that no one is ever happy, people SCREAMED to have martin on the BBC team without James Allen, who I think was too distracted with the contours of Lewis Hamilton's Asshole.
There is no one out there who will do as good a Job, personally I like the inside Line and the banter between Coulthard and Brundle and the anecdotes add spice.
I really dislike commentary that is ridiculously over the top and emphatic like in NASCAR.
I sort of see Brundle in the same light as Mark Skaife in the V8SC.
+1 for Martin.
Brundle has been losing his shit for a while now. Rambles on all the time and misses some of the most blatantly obvious stuff. Can see him being phased out soon
Seemed to serve Murray Walker alright for about, oh, 17,000 years or so.
Damon Hill'd prolly be a decent replacement at some stage, yeah?
Theres a bit of talk about moving the barrier that the Sauber hit, but i dont think thats the issue. That bump in the road that they hit just as they enter the breaking zone seems to be the cause of all the problems.
I mean you can even see it if your just standing there on the road looking down the hill. Imagine how it looks and feels for the guys driving over it. Surely a cheap easy fix would be just to smooth that thing out and all should be well, no? Why go to all the trouble of moving cranes and barriers
It's part of the charicter of the track, doing stuff like that is how we end up with tilk tracks. It's the most prestigious race to win, it's not meant to be easy. Being a temp street circuit it would probably be easier to move the barrier anyway.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
