They should add a snow round to the calender..
Spiked snow tyres for F1?
If the rims come from their tethers it would be a bit Mad Max-ish but it would have to be better than racing in Bahrain.
Plus SebVet could have his 'sauna' and take a good spanking with birch branches or whatever they use.
I cant believe this son of a bitch is still around, he was old when i started watching f1 and he somehow doesnt really looked like he's aged much? Shenanigans
ancient + a handful of years = still ancient
LH from interview on F1.com
Good on you for correcting your initial impression of who was at fault.
Then of course drivers would defend their positions, too. I was rather thinking that perhaps it was more like 80-20, or 70-30, me being more responsible for the fault. Either way I felt that for my relationship with the other drivers, and mostly because of the things that I said afterwards, I felt it was important to correct that and apologize for that.
lol what a goose - he was fairly unequivocal in the post race interviews about who he felt was at fault in all those situations. can only laugh at him back-flipping now. So Lewis, if the other drivers weren't at fault, who's the "frickin ridiculous" one now???
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
