Wasn't Massa faster in the Fez in that last year?
If you read his 2008 season review you can see that there were more than a few times where circumstances out of his control robber him of big points hauls;
- A driving style that did not suit an understeering Ferrari, especially in quali
(which seems to still be very apparent in the F150 italia)
- Drive thorugh penalty for team failing to prepare correct tyres in monaco
(which snowballed into his accident with sutil)
- Lewis robbing him in canada of a win
- Exhaust failure in france gifting massa the win
- Rediculous we weather calls by his team in silverstone
- European GP engine failure
- Italian GP quali fiasco (by both mclaren and ferrari) leaving him 14th
- Handing massa second place in china
And yet somehow matched a record of 10 fastest laps out of the 18 races.
In my opinion only, i think he was very unhappy at Ferrari and a horrible season only compounded his misery. He then took the very next opportunity to return to Mclaren, but for whatever reason didnt pan out that way.
I think the motivation story thrown around is true to a point. Its not tht he didnt want to go racing, he just didnt want to race for Ferrari anymore.
He lost a lot of motivation by the end of that season. I totally agree the points results and stats don't always tell the story of the years racing. Massa looks totally demoralised these days as well. It will be good to see how quickly he gets back on the pace.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
