So its pretty much stock S2 stagea with blitz air filter and exhaust with sbc i colour, i have a little box in the passenger footwell with SIDC box???
it has a mines ecu with :
Fuel mapping has been changed
Ignition timing adjusted
Speed limiter cut
Rev limiter raised plus(+) 300rpm
Guys at autoworx recomending i get a new fuel pump.
I want to get a new ecu as it is.
here is dyno sheet, i believe this is on mid level boost....
https://www.sau.com.au/forums/topic/344518-just-had-my-car-dynod/
Nope.
It is kind of like a piggy back but is sort of like a completely new ECU. It is additional 'address space' and kind of interrupts the factory default values and is placed inside the factory ECU.
This basically allows you to have full adjustment of pretty much everything via the consult port via some cheap laptop software downloaded from the nistune website. For example, I can now change the Thermo fan set point which was usually an 'emergency thermo' for my SR20DET. I've removed the factory clutch fan and now the ECU takes care of cooling duties!
hay man that mines ecu you have the best thing to do with it is to remove it and throw it in the bin !!!!! my mate had one in his 33 and it caused all kinds of problems for him and never tuned properly , and would always lean out on a high boost setting and could never hold a smooth AFR for some unknown reason . seriously man the best thing to to is to spend the 400 bucks on a nistune daughter board installed into a STD ecu and all your problems will be solved . my s2 before i installed the nistune was pulling 235 hp on 10 psi , and 2.5 exhaust std cooler and turbo smart boost tee . now i have a 3'' exhaust , FMIC and coustom intake setup , but i havent had it tuned yet because of getting hit in the ass by a stupid ford driver and having to get it fixed but now i have it back so it should be all go after christmas , and im hoping for around 290 -320 hp at all fours with a goog tuner . cheers spinner ..
How much are they normally
See if this one's still for sale - I think he wanted $400 for the ecu c/w nistune chip - you could just plug it in an get a tune.
http://www.skylinesaustralia.com/forums/Ni...fm-t340680.html
+1
$450 I recall for the ECU.
Thats if its still available. The thread was killed by some non-buyers tearing at it.
The board itself is about $280, a single user license for the NIStune software is $200 I think (you don't need this, it's only if you want to be able to fiddle with stuff yourself, or ask me to do it :) ) - both purchased straight from NIStune.
Carton of beer to a competent electronics technician to install the board.
Then find your tuner of choice (I can recommend Hyperdrive and Allstar Garage) and pay by the hour for tuning. Shouldn't take too long as it's pretty much stock.
Edited by bubba
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
