hey guys,
Well the other day i filled up at a shell - was driving down the road and thought i'd check how many k's i can get outta a tank - so i hit the trip metre reset.....as soon as i did the trip metre stoped working (still sitting @ 0000000) and my main KM's odometre is 'stuck' just as it's changing to 64200 km's
i could be happy about this - keeping the k's low etc, but iw ant to service reguarly and keep the car totally legit! I am thinking perhaps a spring has come loose or something?
I know nothing about how they work etc - so i have no fuc|;)
https://www.sau.com.au/forums/topic/34474-my-ks-aint-clicking-over/
Same happened to me. You are looking at 90 dollars to fix it which involves taking it out and finding a place near to you or about $100 - $150 on buying a replacement odometer.
Its only worth fixing if you can spare the time. I think it's much better idea to replace it if you can find one with similar K's on it.
Oh and they break because they've been wound back... which you knew since you have a 93 R33 with HAHAH 64200kms on it ;)
well i fixed it
the problem wasn't pushing it in - when i pushed it in, it got stuck in - so i pulled it and it clicked then it's working again now..
you guys think my odometre has been wound back? i guy i know looked at the seal around the box and it seemed to have not been tampered with - the car was brought over here decmeber last year and had 4 k's on it after comliance - japan is a small place :)
My '98 had 66,000km on it when I picked it up.... so it can't be that small.
How worn is your interior? have to be pretty schmick of the k's are genuine.
Another way to help tell if the car has had k's wound back is to check if the factory bushes are still in place in the suspension. These won't last 100,000km so if they are still there and not aftermarket items there is a good chance that the kms are genuine. However they could have been replaced with factory items, but why would you if you can get better aftermarket ones for about the same price.
My 1988 VR4 had 58,000 on the clock and they are original km's as the car is immaculant inside and only dirty under the bonnet. I used this Simple Green stuff and now it looks brand new. The body looks like it lived its whole 16 years outside and been washed in a auto car wash 1 million times, but you can tell if the odo has been fiddled with, you cannot hide wear and tear.
It has always worried me about imports and odo fiddling, it looks like it does happen often from some of the posts on this thread.
Mal
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
