hey guys,
Well the other day i filled up at a shell - was driving down the road and thought i'd check how many k's i can get outta a tank - so i hit the trip metre reset.....as soon as i did the trip metre stoped working (still sitting @ 0000000) and my main KM's odometre is 'stuck' just as it's changing to 64200 km's
i could be happy about this - keeping the k's low etc, but iw ant to service reguarly and keep the car totally legit! I am thinking perhaps a spring has come loose or something?
I know nothing about how they work etc - so i have no fuc|;)
https://www.sau.com.au/forums/topic/34474-my-ks-aint-clicking-over/
Same happened to me. You are looking at 90 dollars to fix it which involves taking it out and finding a place near to you or about $100 - $150 on buying a replacement odometer.
Its only worth fixing if you can spare the time. I think it's much better idea to replace it if you can find one with similar K's on it.
Oh and they break because they've been wound back... which you knew since you have a 93 R33 with HAHAH 64200kms on it ;)
well i fixed it
the problem wasn't pushing it in - when i pushed it in, it got stuck in - so i pulled it and it clicked then it's working again now..
you guys think my odometre has been wound back? i guy i know looked at the seal around the box and it seemed to have not been tampered with - the car was brought over here decmeber last year and had 4 k's on it after comliance - japan is a small place :)
My '98 had 66,000km on it when I picked it up.... so it can't be that small.
How worn is your interior? have to be pretty schmick of the k's are genuine.
Another way to help tell if the car has had k's wound back is to check if the factory bushes are still in place in the suspension. These won't last 100,000km so if they are still there and not aftermarket items there is a good chance that the kms are genuine. However they could have been replaced with factory items, but why would you if you can get better aftermarket ones for about the same price.
My 1988 VR4 had 58,000 on the clock and they are original km's as the car is immaculant inside and only dirty under the bonnet. I used this Simple Green stuff and now it looks brand new. The body looks like it lived its whole 16 years outside and been washed in a auto car wash 1 million times, but you can tell if the odo has been fiddled with, you cannot hide wear and tear.
It has always worried me about imports and odo fiddling, it looks like it does happen often from some of the posts on this thread.
Mal
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
