We had the 2nd round of calender shots last night. A little bit of studio and some more light painting. pics will be added through the week by Kory and myself.
All in all it was a good night. The music courtesy of GTRSean and Beverages courtesy of N1GTR certainly added to the shoot.
Check back for pics later.
Feel free to chat about the night in the mean time. :)
https://www.sau.com.au/forums/topic/345069-sau-calender-shoot-night-round-2/
  • Replies 48
Posted Images
Really impressed with Kory's and Matt's professionalism > even down to one of them not swearing after dropping a flash unit on the tarmac - not that I could hear anyway. :)
Was busting for a leak afterwards - don't know how those girls could hold it for so long! :D
So pleased to have met up with Sean/Andrew/Annette/Steve-O/Paul/Owen/Sloane/Mamoon/Sean :D
Not so pleased with being within earshot of Matt's jokes :)
Hahaha great night. Jokes are what makes it appealing for people to come along not the photography haha.
Matt didn't swear because secretly he wants new gear :P
I got home at 1am. Was no way i was going to edit pics. BUT I DID. One anyway. It's no where near finished, i'll post it up on lunch break.
Good to meet everyone, hope Owen got home at a reasonable hour and the rest of the crew. Hope everyone enjoyed the night, thanks to Steve-O for the beers and Terry for assisting the missus with holding the lights/various people carrying my gear around.
+11ty at worst excuse i've ever heard!
Edited by FST513
what the hell is the 3rd guy in the black shirt doing behind us? :P i feel so violated!!!! (and very slightly flattered)
that just looks heaps suss!!!!!
Also thanks to the crate movers and cleaner uperers. you know who you are :(
I'll try to get one pick up later tonight.
I was playing with my e-peen and it's a grey shirt lol
Had a great time yesterday, thanks for including my car in the shoot and thanks to Matt/Kory/Missus for all the time and effort you guys put in. Can't wait to see more results.. looks sweet so far Kory :D
Was a good opportunity to get to know each other a bit more and put a name to a face. Thanks for shouting the beer Steve, I'm glad I only had 2 lol.
I got home around 11:45pm so wasn't too bad. At least I didn't have to contend with traffic.
Where was my phone call, punks?!?!?!
You mean Matt and Kory, right Terry?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
