I know you aren't really supposed to start your car while the A/C compressor is switched on, but has anyone else noticed if they do it first thing in the morning, the car doesn't like it at all.
I get oil pressure warning lights and whacked out engine idle which prompts me to switch the car off straight away.
Happen first time yesterday, and then again this morning. If I switch it off and start it again with the A/C turned
off it's fine. And if I try start it again with the A/C switched on it's fine.
Or is it just mine??
https://www.sau.com.au/forums/topic/345088-starting-m35-while-ac-is-on/
  • Replies 67
Just yours, I would clean the battery terminals first, sounds like an electrical/earthing issue.
The old adage about AC being turned on really only applies to older cars. Even the C34 stagea's dont engage the clutch on the air con straight away. My old series one used to turn the air con off breifly when I buried the right slipper even. (something I wish all cars with an automatic gearbox did - best idea ever IMO)
Ok, I didn't know all of that, but I will check everything stated above.
It seems to wind over fine, batter isn't showing signs of low power.
But will check it anyways, cheers.
See how you go, a quick terminal clean up with some emery can fix a lot of electrical issues. Check the earth straps also.
don't waste the Vaso Cam!.....you'll need it when I come down in another week ;) ......oh yeh I found a nice big stick for you to bight into as well!
let me know if you run out....I have some really good KY that Andy and I have been testing!
Edited by Jetwreck
don't waste the Vaso Cam!.....you'll need it when I come down in another week :ermm: ......oh yeh I found a nice big stick for you to bight into as well!
Craig. Theres this line..
Normal
Aaron, Andy, Cam .
___________________________
Abnormal
Craig. ;) Iain.
lol
Edited by AaronNM35
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
