First off back in 2003/2004 I imported my first Gts-t... Was a great little fun car with a RB20 and Apexi turbo making 220 odd rwkw
http://www.youtube.com/watch?v=lp2QUSzZFa0?fs=1&amp
http://www.youtube.com/watch?v=jf7fbJvImwY?fs=1&amp
I then sold that, purchased a R32 GTR (spun a big end bearing about 10 days later) and then begun the process of rebuilding the motor and strapping on a T04Z. Ended up with 430rwkw and the thing was a bullet but I needed to move on with my life and buy a house so I sold it :P
So I had got my house but was missing all the fun (and annoyance of owing a R32)... I found this Black manual Gts-t (with a shocking white bodykit) for sale one SAU for cheap!
Unfortunatley the reason it was cheap is the owner had fallen asleep at the wheel and caved in the front end, so this is how it got back to my garage (had been partly dodge fixed)...
  • Like 1
https://www.sau.com.au/forums/topic/345095-another-r32-money-pit/
The car was pretty much stock with a cat back, it needed a fair bit of work and I took the time to do some basic stuff while it was off the road.
Removed all the HICAS lines and pumps etc and fitted a lock bar (saved about 20kgs)
Removed all the air con (saved about 30kg)
Whiteline Castor kit
Whiteline subframe bushes (Pineapples)
Bought some 17" Gtt rims
Fitted factory Type M skirts and pods
The sunroof was stuck open, most the paint was pretty fvcked or had different colour panels so I tried a few DIY paint jobs and failed so I ended up getting it running and taking it down to my mate who is a painter over here in Perth BBK.
Just about ready to leave after putting it all back together!
On the way to get painted...
Half painted :D
Back at home
Edited by SimonR32
So I got a little carried away with my suspension, ripped out the parts I had already installed and decided that rose joints pretty much all round should do the trick ;)
HKS Hypermax Rear coilovers and Top Secret Fronts (came with the car)
Kazama Castor Rods
Kazama Ally Subframe Lock Bushes
R32 GTR Rear Swaybar
Rear Adjustable Camber Arms
Rear Adjustable Lower Control Arms
Rear Adjustable Traction Rods
Edited by SimonR32
Care to share what brand those lower arms are?
All the blue arms are from performance-guru off ebay (from the land of the sheep shaggers)
I did a bit of research about them before I purchased and they are made in Taiwan not China, seem to be very well made and I know some people who are using them in drift cars for a few years now and they are still holing up strong.
Website to company that makes them http://www.si-racing.com.tw/
Power time :blink:
Installed
Walbro GSS-342
R34 GTR Injectors and Ballast Resistor
Z32 AFM
Nistune Board
Just Jap Bell Mouth Dump pipe
De-cat Pipe
K&N Air Filter
Hypergear low mount ATR43G3 with a 0.63 Rear
Turbotech Bleed Valve
Add 22psi on BP98 and viola!
Also added some front camber arms
It was time for a bit of a driveline beef up, looks pretty much stock under the bonnet as well :whistling:
Front mount and Pod filter = 260rwkw
OS Giken Triple (Overkill)
R33 RB25DET Gearbox
ATS 1.5way Mech Diff
Edited by SimonR32
How do you find that turbo on the RB20?
Very good top end, very average down low... But that pretty much is every turbo on a RB20!
Got bored with 260rwkw so decided to do a E42.5 mix. 50% BP98 and 50% CSR Sucrogen E85 (we don't have any E85 here on pump in Perth)
Comparison of BP98 and E42.5 (same boost level at 22psi)
So after stripping 3rd gear I got a little miffed that I had to punch gears so hard just to keep the little 20 in the power band...
I hatched a plan to chuck a RB25 in the old girl and keep most of the same supporting mods :)
That didn't go to plan because I was thinking about everything too much so I have ended up with this plan
Nistune RB20 ECU and loom
Greddy MSS for switching VCT
Yellow Jacket Coils
740cc top feed Deatschwerks Injectors
Ally fuel rail
Bosch 044 in tank
Z32 AFM in cooler piping
VH45 Throttle Body
Freddy Inlet Plenum
6boost manifold
Kinugawa (Kando Dynamics) T67 10cm T3 Rear
Tial 44mm MVR Wastegate
Stock RB25 motor
Adjustable exhaust cam gear
Greddy Profec B Spec II
Getting started, RB20 out and RB25 in the hole
Edited by SimonR32
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
