Hey all,
I spent a good couple of days last week reading all the threads in the FI section and the general maintenance section to make sure I bought the right spark plugs for my car, and I ended up going with NGK Iridium BKR7EIX which are gapped to 0.8mm from factory; only put them in my car on Friday.
But my car is now with Andrew at Hyperdrive waiting to go on the dyno and he called me up to ask what plugs I have. When I told him, he said they are definitely going to have to come out, the plugs need to be gapped to a maximum of 0.7mm but ideally 0.65mm. So it appears I have wasted a hell of a lot of money as the Iridiums can not be regapped and now Andrew thinks he will needs to waste dyno time seeing if they will misfire, then waste time removing the plugs and replacing them, etc.
But wherever I look on SAU, everyone recommends using 0.8mm gaps for boost over 12psi. I'm not sure what boost he is intending to run, I know the turbo I'm using has a 20psi atmospherical actuator so low boost will probably be around 15-18psi. I had been expecting the car to make between 350-380rwhp on high boost. Are his fears correct and I've made a mistake choosing those plugs, or am I getting in a panic over nothing?
Cheers,
Martin.
https://www.sau.com.au/forums/topic/345346-spark-plugs/
I went to the drags last week and was miss-firing down the strip, that was about 1.3 bar and the plugs are ~7,000kms old. It got worse as the night progressed :blink: Still, I managed at 13.036.
I think next plug change I'll be looking to re-gap below 0.8mm, but I just use copper plugs. Why can't you re-gap iridiums?
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5563856
Yeh and KYP have put all sorts of sensors on the valley cover that need to be unplugged and removed. Took me about 3 hours to do it on Friday, but it was the first time I've done it on a Skyline. Could probs do it quicker next time.
I just got Iridiums because I figured it's better to spend $85 once every 60000kms than however much coppers cost every 5000kms.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564031
i have a brand new set of the copper plugs you need sitting here if you need them asap
gap depends on a few things, mainly boost and condition of your coilpacks. but unless you have some really good coilpacks you'll need a smaller gap than .8 for 15+psi
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564365
When i used splitfire coilpacks i was running .8mm or maybe a bigger gap and no misfires with 18psi.
I always replaced my sparkplugs every 5000kms with copper ones.
If you are running original coilpacks, i would gap a set of copper plugs down to .6mm to stop the misfire problems on high boost.
Otherwise get a set of aftermarket coilpacks and stick to the iridiums since you have trouble taking out the sparkplugs.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564614
Bro, if your actuator has a spring pressure of 20psi you wont be able to run under that boost pressure...
Yeh 20psi atmospherical, so at the manifold will be 15-18psi. What I've been told anyway... My boost gauge reads 16psi with the boost controller switched off, so I guess that's correct.
coppers all the way man, do not bother with iridiums - you should have picked up on that if you did read all the threads :P
change them every 2nd or 3rd oil change :)
I know, everyone vouches for coppers but I went for Iridiums because I didn't want to be changing plugs every 5000kms lol. I will probably go with coppers next time.
Anyway, car doesn't have any issues as far as I know... I have Splitfire coilpacks. It does have a slightly rough idle like it's misfiring at idle but I thought that is more likely from the 650cc injectors not the spark plugs???
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564768
5000kms is far too early for coppers!
ive done 12,000km on mine (bcpr7es), still like new and never mis fired - I run a heat range 7 though as i dont waant any chance of pre-ignition although a 6 would be better for a daily driven car but eh, better safe than sorry
ill change mine at 15,000km even though i know they will go more, just good to keep it routine instead of waiting for a failure
Edited by snozzle
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564769
Use NGK copper BCPR7ES and gap to .8 and will be sweet
Try for the ones without the R if you can though. From memory, the R is a resistor type or something and has a slightly weaker spark... but it's there to reduce electronic knocking/pulses? I should google it- no wait, you google it for a better answer.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565355
This. Dont know why everyone does it at 5,000km. When I pull them out after 10,000km they still look fine.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565358
Probably depends on your tune/mods and how you drive as well I guess. You're a pussy driver and have no fast and furious mods, so yours last longer :bunny:
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565367
I am using irridium plugs and have been for the past year or so. No problem what so ever with them. on low or high boost and they are gapped at 0.8... and I am still using standard coilpacks at the moment as they are still going strong.
I used them for the same reason as Hanaldo... I didnt want to unplug / unscrew everything every 5k or so...
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566341
The trionic system uses the resistor ® type spark plug to read combustion chamber conditions and "inform" the ECU about boost and ignition advance requirements for the engine in real time and continuously. This is why you must use resistor type plugs
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566350
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
