The only thing about inside cooking (unless lots of ventilation) is that if onion is wanted I may needs to leave because of stupid allergies.. Not planning on dying this weekend :)
I just came back from a drive out to Tidbinbilla in the R32. The only way out there from the south, is through Tharwa. Wasn't a bad drive, except I found more damage on the R32.
Corin Road is also closed but I didn't get all the way out to the cotter.
I didn't realise that the cruise was on saturday. I have soo many things to goto so I'll probably bring the Silvia and hang around for a while.
So what have we got as our current plan for tomorrow? Are we still meeting for a chat etc at gravalia, then going for a bit of a cruise before a bbq? Not that I'll make the BBQ, but curious to know what the final verdict on all is.
Also Trozzle, hopefully will catch you tomorrow and can grab that manual also. Ta mate.
I went back to the river today. Looked a bit better, still soggy though... If this sun stays out it should be ok to go there still.
The only problem could be the gate at the entry... But somthing magical might happen where the gate somehow gets opened for us
11 am this morning, come on sun!
The suggested cruise route is still OFF.
But the road to the river from western creek is still good as ever... so we'll just meet up at grevillia park then kinda go straight there via commonwealth av then cotter road
:D
  • Like 1
Yeah man that's cool. We'll DECIDE by this evening imo. Since it's still looking to be sunny, I reckon we'll be going to the river anyway...would much prefer to be out in the open personally :)
What time we aiming to get to the river? Plus I need a map coz I've honestly never been to this spot before.
I'm keen to get there a little early and start scouting for remotely dry firewood.
You're so shit! We put up fool (ie Troy) proof directions in the other thread... do you read nothing??
Cotter Road --> right at Uriarra Road
The picnic area is Uriarra East, you can't miss it.
and lol @ dry firewood
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
