gday guys,
having a rb25 and box dropped into the 32gtst in the coming weeks with garrett 3071, power fc, injectors etc and am wanting the car the have a high/low boost setting ideally. my question is which one of the controllers would be better suited to my mods.......avcr or an eboost???
thanks guys for your input
mick
https://www.sau.com.au/forums/topic/345656-boost-control/
Than E boost 2??
I don't think so.
Have a read.
http://www.turbosmartonline.com/index.php?...load&id=350
i've used eboost on my r32 gtr, had a friend with eboost 2 on his turbo R1 and they are rubbish hard to install hard to set up, BSM had the profect on one of the race cars ages ago and that was easier to use,i now have the apex'i fc with boost control on my r34 gtr and don't like it, i currently have a HKS EVC 5 on my r32 gtr and have just recieved a HKS EVC 6 for my r34 gtr, they are plugin to each conponent and you only have two connect two-three wires earth power then turn on and set warning level and then turn up done.
as for eboost they are only electric bleed valves not full controllers that is why they have pipe to atmosphere
https://www.sau.com.au/forums/topic/345656-boost-control/#findComment-5569501
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
