  • Replies 50
Both cars?
Shame, things didn't work out - apparently?
1.01.6 is slower times than R35 Duncan & Marek & our old R33 does, all road rego'd at Wakefield.
Hopefully,the VZ's were sorted better for Homebush than Boz's clip?
Any Clues Boz
Any Clues Boz
hahahahaha who said I am not doing the series :action-smiley-069:
Drive the GTR's in rear wheel drive and see what they can do :thanks:
or just put them in a taxi and see if they get close to 1:01 with 2 days worth of testing and old rubber.
Boz I got your text, missed your call, been trying to get in contact with him but each time one or the other has been busy. Will happen soon enough.
I'll call you wednesday anyways will arrange something by then. Snooze you loose as they say.
So whats the new car?
On quicker tracks, the 33 has proven better in 2wd, but there also 1600kgs+ and aren't 35's around the 1850+ mark
Did, earlier wish you the best Boz - still do - maybee see you in 2011.
Well maybe, we will see how we go in 2011 if PE42 is only a taxi I had better keep looking! Although spec'd up nice on the phone.
Cheers
Thanks for the luck Stuart :D
It all comes down to "show me the money" with what we will end up with.
There has been so much going on since Homebush, that it changes many times each day.
Alot of AWD's are faster in 2WD.........and that may mean allowing the Motec or whatever switching to FWD or RWD at various points on a track, depending on the circuit of course.
In Prod cars, alot of teams think FWD is faster in there AWD's.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
