Well just had a very disappointing phone conversation with a certain 2nd hand parts Japanese-IMPORTS business, that has absolutely no interest in supporting the products he sells. His words; "As soon as you pay for it and take them home, it's your problem".
A while back, i bought a set of rims, but before being able to fit them to the car, i had an engine fault that required a rebuild. After the car's maiden cruise to Mt Bulla, i had a flat tyre, so i took it to get repaired. Unfortunately there was no fault with the tyre, but a crack in the rim caused the air to escape. There is also no external damage to the rim (apart from the crack).
To be honest i didn't expect this guy to happily replace the wheels, at no cost, but to come to some sort off arrangement where i'd be well looked after (ie: he does not make a profit on the replacement rims).
It just amazes me how people with such a lack of people skills still remain in business. I guess the % off shit that farks up and thus the % of clients he burns, does not out weigh all the other sales that happen to run smoothly.
If you need to know who this guy is shoot me a PM
I am now off to see a wheel repair place, so they could assess whether the rim is repairable.
If the rim is not repairable i will be giving Aaron at Import Monster a call, to replace these rims. Should have used Aaron in the first place!!!
Rant over :banana:
https://www.sau.com.au/forums/topic/346020-buyer-beware/
  • Replies 48
Posted Images
Rant over :banana:
Im really sorry to hear that Al.
Aaron is the greatest man I know for pretty much anything Import Related. New or second hand, it doesnt matter. If he has the contacts you will get it....and at a great price.
Not long ago he hunted down for me a NEW OEM fuel tank for my EMO 6 from Japan......and at half the cost Mitsubishi Aust wanted. The dude is AWESOME
/mancrush
https://www.sau.com.au/forums/topic/346020-buyer-beware/#findComment-5573003
I know what you mean.. when i took my car for a check on a engine fault he told me the problem, left the car with him and when i came back the next day told me it was something else and he still needed $250 even though there was no work done to the car...
Some people... sad world.
https://www.sau.com.au/forums/topic/346020-buyer-beware/#findComment-5573018
Rang up Neway Wheels and was advised that they no longer repair cracks in alloy rims as it may re-crack and cause an accident. I had also been advised by my metal fabricator (when i asked him to weld my spacers to the rims) that welding alloy softens the material.
So looks like i'll be giving Aaron a call. Hopefully he could track down a pair of ragamasters 18x8.5-35, otherwise i'll just buy a new set and use the rears for DECA :banana:
https://www.sau.com.au/forums/topic/346020-buyer-beware/#findComment-5573041
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
