Am I the only one not getting notifications at the moment for new posts
Since we have this new board Im not getting them
I have looked at all the settings and I think I have them right. Please help
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5587248
make sure your settings are
1) Notification Options
2) Under - Notification Preferences
0 Show popup when I receive a new inline notification
This option will cause a popup to be displayed when there is a new notification for you to review
1 Include a copy of the post when emailing me from a watched topic
Enabling this option will send a plain text version of the post in the watched topic email.
1 Watch every topic I reply to
o If enabled, choose default notification type: Immediate Notification
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5587251
Any chance of getting titles on the inline notification list?
I had 14 notifications and didn't know what they were for, all were blank. Until I clicked the link for the page then found out.
Just would make it easier to find the topic I'm after :)
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5588754
I wish Sau 3.0 had "egosearch". For those who don't know what this is, it's where you are able to see all your posts and replies in a topic setting. Thus it's easy to keep up to date with things.
In Sau 2.0, this was done by searching the forums with your username only, and having the results sorted by date. Sau 3.0 can do this, but the results are buggy. Even though I've checked the option for sort by date, the search results are all over the place and buggy.
Suggestions?
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5589386
I hope so :)
Cos i've got a few trader ratings to leave/receive :)
Got it!
Stuffed up in my last post, you only copy everything after "topic/" not "forum/" (left a trader rating just then and it worked)
so in >THIS< thread:
http://www.skylinesaustralia.com/forums/topic/346495-sau-30/page__st__240
just copy:
And paste it into the "Deal Topic" boc. (but for the thread in which the "deal" started)
Hope this helps everyone?
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5589643
Suggestions?
Hey mate,
If you go into the top right hand corner of your screen, (with your profile pic and the "sign out"), click the arrow next to your user name, and click on "My Profile".
Now, directly below your profile picture on the left, theres a "Find My Content" link, this brings up all your posts for the last year.
Is that what you're looking for?
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5589647
Hey mate,
Ah nice, yes that is the thing I was looking for. However, looking at the results, it's still not showing them properly. The most recent replies should be first, but it's ordered them with some that havn't had replies for 6 months, some last week etc. It's all over the place and not sorting them as it should be which is newest first. Sau 2.0 sorted this just fine, but 3.0 isn't working at all in this regard.
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5589670
Rep me lol
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5589731
Madaz, correct you have a few options there with username, and or posts by username, but it's not usable if you have to goto the 4 page of results to see a reply that occurred today for a topic. And in between we have 1 year of posts. So there's definitely something that isn't configured or working correctly.
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5589834
Got it!
just copy:
It worked!!
We have a winner :) Hah
Thanks mate, greatly appreciated
https://www.sau.com.au/forums/topic/346495-sau-30/page/13/#findComment-5590212
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
