I have spent probably 8-10 hours on the phone with Optus over the last 4 days (including xmas) because the error message said the problem was at my end. I was about to buy a new modem tomorrow when everything opens again, lucky the problem sorted itself out!
  • Nope 5
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602783
lol ring optus because SAU is down surely all your other web pages worked
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602831
if theres a site down and you wanna know if its a problem on your end, use this site http://www.downforeveryoneorjustme.com/ and it will tell you.
also yay that SAU is back
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602837
<br />lol ring optus because SAU is down surely all your other web pages worked<br />
<br /><br /><br />
Perhaps you were not getting the same message I was getting, something along the lines of "The problem is with your server not the board. Please contact your service provider". I clearly am not the tech savvy genius that you are, and for that I am infinitely sorry but I don't see how can you lambaste me for seeing that message and arriving at the conclusion that I might need to call my ISP.
  • Nope 1
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602931
When did I ever say that no other website worked. I know nothing about the interwebs, but if I see a message saying the fault is at my end and to call my ISP then that is probably what I am going to do. But theorise with me, is it totally impossible for websites to use different technologies, so that if something is wrong with my service it effects only certain sites, whilst leaving others fully accessible. ie a board such as SAU may use something different than a regular website where one only visits and views as opposed to views and contributes. Maybe you can use your degree in IT and Computer Science to set me straight. You called me out buddy, tried to get a laugh at my expense, maybe get someone to agree with you, maybe a "good call bro" or something, trying to gain affection and/or approval from your peers, maybe you need to feel as though you fit in. I don't know, maybe next time you feel you need to step in and belittle someone you will think first. :)
  • Nope 6
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602945
Its call the internet and the world wide web.
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5603241
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
