  • Replies 75
UM let me guess.......................STOCK AS A ROCK!!!!!!!
If you had mods and posted 153rwkw from a car that has 190 odd flywheel kw factory spec, wouldn't you be :Oops:
Thats my guess!
That's a pretty good power output then when you can consider the following:
* Full 3" Turbo Exhaust = 10-15rwkw
* Ex Cam Gear = 10-15rwkw
* FMIC = 10-15rwkw
Their's a potential 30-50rwkw just from another $3,000.
I got 160.6rwkw from AVO with known mods pod, clutch.. though a/m boost guage was showing ~10psi top end but still using the factory solenoid so there might be more mods than that (as factory solenoid is supposedly to be 5->7)
Exhaust looks stock as far as I can tell too.
dyno graph
dyno graph
wow 160 for those mods
very nice
was this on the race pace dyno mupkant? i got 153rwkw as well with safc pod boost but i have an exhaust, mine should probably have more power but i dont mind because im getting cool suspension soon and should be able to turn a lot better :)
i have no idea, but originaly they dynoed it with only boost and it was about 142rwkw, then with the tuned safc, they said i got an extra 10 or more rwkw.
Not to mention it was dynoed on friday which was 36 degrees day.
dyno graph
ive heard plenty about the AVO dyno readings...
Inark, it was on an official WRX club dyno day and everyone else who had their cars dyno'd - majority WRX though, didn't seem to be concerned about the figures (people who have dyno'd else where too).
So since it wasn't just me by myself there'd be no need for them to try and boost the readings.
From what I've heard AVO is supposedly as accurate as Docklands STI's one too.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
