Drag Combat
April 10th at Kwinana Motorplex
There is a round of Drag Combat being held in Perth on the 10th of Arpil and SAUWA is looking for people interested in entering as a team. Skylines Australia is supporting the event with advertising and teams are entering around the country with the 1st round having been completed in NSW at the WSID (Western Sydney International Dragway).
You don't need to have a 10sec car to be able to compete, aslong as it's able to do a 14.99 pass or better then your eligible. We're not restricting it to just Skylines either, any Jap Import owner who is a SAU forum member is more than welcome to join us, and I believe cars with engine translplants are eligible aslong as the engine is from the same manufacturer.
There are prizes to win, and the event will be shown on FOX SPORTS, so if you have sponsorship this may be a good way to get some exposure. There are different categories of racing, including a category for street tyres. Further details can be found at www.dragcombat.com .
There will be a Show'n'Shine and SPL comp, but if you just want to race then you don't have to enter them:D
I'm talking to the organiser to get a discount for SAUWA entrants, and will let you know ASAP what the discounted rate will be.
Please register your interest, and support this event.
Paul
President of SAUWA
Entrant List:
GTS-t VSPEC - R33 GTS-t
SHUTO BOY - R33 GTS-t
DSTURBD - R31
RB20LAGWAGON - R31
ROB77 - R33 GTS-t
REP003 - R33 GTS-t
https://www.sau.com.au/forums/topic/34755-drag-combat-1004-who-wants-to-enter/
  • Replies 109
haha. wikkid aidwin.
wing 55 - unholy dragstip warrior.
I will probably not be in on this one, due to the fact that my car is slow, and my wallet empty, thereby precluding any change from the current scenario of car slowness.
but I will be there - and may spl it up if required.
Sean, We have a few decent cars, may even have an 8sec GTR making an appearance, but have to wait to hear back:D
Once we've confirmed some more people, then we'll get together to discuss what brackets, dial in's and tyres we can use. We can always have a couple sets of slicks that we share between some cars.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
