Make sure you keep a couple of packs for Giant. He rates them highly for those long Brisbane to Darwin drives he does so often.
will do. got some for you and some for our telly tubby look-a-like mate, rusty. will even throw a few berry's way though he's baby making these days and may not need them. not sure we want russ driving one handed from darwin to brissy though. he is bad enough of a driver with both hands on the wheel!
Beer!
BTW, Queenslanders, we're road tripping it down obviously, we'll be taking a dual cab tilt tray with my car and a dirty big f off Snapon roll cab.
I'm asuming we'll head off Thursday AM?
If you need a hand with your car Marlin let me know, stacking tyres whatever, I work for free.
also, there should probably be some form of Karaoke ? LOL
Coop, bring it down mate, the thing is a weapon!
Haha righto. Pull some strings for me in the tyre department and I'll do it. Otherwise I'll just pit crew for you. I'm a machine with a tyre presure guage.
Mate I think I'll be actually Purchasing tyres!!!! Rare I know!
I sold my old falcon last week so I've got a bit of play money for tyres and brakes and was talkin to the mrs last night and she seemed half keen to tow the junker down there. Never know.
Well, looks like I am out for the 3rd year in a row. Been trying to convince myself to do this...but bugger it. But deciding will do Zandvoort on the 4th August instead :) Means I can sneak in the Hungarian GP as well rather then spend 4k on entering Superlap. One year! :)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
