he ran a 9.7 but cant remember the trap speed.
I do remember Mr DirtGarage making a heap of excuses as to why Mark/Russ went quicker, with smaller turbos and circuit tyres lol
9.78 @ 143mph.
It's funny to listen to Berry tell the story, particularly how they said it needed a parachute over 140mph even with the big brakes.
Marlin
Posted 17 May 2011 - 12:17 PM
I hear the Pulse boys are running a super-duper-wow-spec-epic Rado style front wing on their thing.
That's just wrong. It's at that point one should look at something and go "yep, that might work but it just looks dumb so it's coming off".
9.78 @ 143mph.
wont be as extreme as that more F1ish on the pulse evo still getting the body done currently looks good and wide ;)
What tyres are the guys in Club srpint class running?
I was reading the regs and it suggests you have to have UTG of above 120. Aparently this rules out my Dunlop 03g semis. Therefore what is the stickiest thing i can buy that complies.
Love to hear the feedback.
Cheers,
matt
for clubsprint I would recommend looking at the dunlop Z1 star spec. I currently have AD07s on one of my 32s and AD08s on the other and the dunlops on the evo and they were fantastic and wakefield. for a street tyre they handle track use very well. very progressive at the limit, surprising high level of grip and of course good feel through stiff construction (all the premium tyres have that thouh, RT615, AD08, RE01R etc).
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
