Notice his boost reading is blurred out too..
Only once for a minuscule second did the RPM drop into the high 4000's, there is a lesson to be learned here kids...
Also, awesome SR to allow it to live at that sort of RPM reliably.
If a tyre is DOT certified doesn't that make it road legal somewhere in the world; thus a semi? (serious question not a sacastic remark)
If you're going to the extremes of saying that even they're if DOT approved it's not a 'true' semi, I would raise what is the point of these ultra ultra soft 1 lap qualifying wonder tyres, except as a supplier you're going to get more people buying more of them to be competitive ... /sarcasm
Point is that the big boys are most likely going to have some sponsorship with tyres so the relevance is lost in out-right times. It's more so in the Open Class, where by 'joe citizen' is likely to gain better times with more track lapping (especially the Interstaters without local track knowledge) with a DOT R6 or Z214 as they are a more consistent tyre which are more readily available in the different sizes required by non off the shelf circuit sprint cars. This is compared to the way it currently is with he/she who has the most money to throw new uber tyres at their car each session (on top of their car build) will more than likely go quicker, just by virtue of always having better grip.
time attack don't recognise them as semi slicks. CAMS don't recognise them as semi slicks. AASA don't recognise them as semi slicks. They're not permitted in any road rallies. ANd they're not road legal. Time Attack/Superlap has always been on street tyres in Japan and here and I think that's the way it should stay.
Besides, if you did allow the Hoosier R6 type of tyre, you have exactly the same problems with people using a new set of ultra soft A6's each session.
Even if they banned these ultra soft tyres, the top teams would still be using a new set of Mediums each session, because they're fastest when they're brand new. That's just the nature of racing - and not just time attack. Its the same in any class of racing and rallying - those who can afford it will use new tyres as often as possible to get that slight edge. While others may just race on second-hand rubber bought off those guys up the pointy end. That's just the way motorsport is.
Edited by hrd-hr30
The whole tyre usage issue could be avoided by limiting the number of tyres available to the competitors. Maybe open should be restricted to one or two sets to discourage using them like the pro guys. A no rules event will always be dominated by the biggest budget but this might level the playing field a little in the lower classes.
We could only afford one set.
Hey Russman, good to put face to the name. Also good time in your R32 GTS-T which I thought was a GTR. 1 min 42 is faster than 90% of local gtr's.
About the times comparing Superlap cars to V8 Supercars, the V8's are obviously regulated and much heavier than most of the Pro class cars and designed to do lots of laps, but still....
Yeah John. Good to meet you too and thanks for the advise. I'll be in touch sometime to get some of your awesome upper camber arms :)
I think people would alter setup until they thought they had it fastest on the Friday with their first tyre set, then first or second session on Saturday morning, BAM, smash out their best time.... then use the remaining sessions to burn the tyres up with crowd pleaser skids :)
That's what I'd do anyway.... hypothetically, IF I could somehow afford two sets of tyres! :)
Edited by Marlin
+1 - think that would work.
Also - make it so that only M compounds and harder are allowed for Open. This way there might be a bit more of a split between the Pro Class times and Open times.
Me too! Chase setup until you think it's the best it'll be then wind up the boost and go for it! haha.
Interestingly I spoke to the Hankook guy and they only have softs and hards. No mediums yet?
Really, you know for certain? I'm intrigued! :)
One of the tyre dealers down here offered to bring some super softs up, and do tyre fitting etc. He was told that the Jap guys were brining their own tyres, and the compounds they are brining arn't avaliable to you. He has done stuff like this in the past, so he wasn't just getting fobbed off
Well, the winner, Cyber, hadn't even seen the new 295 Advan prior to their arrival in Australia, in fact they were busy cutting the car up to make them fit when we arrived! lol
Cyber got their tyres out of the same bin we did. All stocks of Advan 295's came directly to Australia, not available in Japan.
Edited by Marlin
And people wonder why others talk of special tyres rumours around the pits on the weekend ;)
I like the tyre & compound limitation idea in Open & Clubsprint. Would help keep the field closer as well as help differentiate the Pro times/budgets to those in Open. Clubsprint limit to only 6 tyres (can replace a non planned tyre if it's damaged or unsafe for continued use at scrutineers discretion), would be similar to what's meant to happen in Targa (correct me if I'm wrong Savman/Marlin).
Using Data dot with info allocated to the particular entrant is the go (as done at Targa in years past), rather than simply white pen marking. We all know how easy it is for a cheat to replicate a car number on a tyre in white pen.
FWIW, upon return from Tsukuba, "we" were convinced that the Japanese guys had special tyres, because they were Rupert after only a lap or two..... but have since discovered it's how they're used, as previously discussed.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
