Hi guyyys and Grrrrls,
I had stupidly decided to purchase some new rims for my car which are Work Meister S1's:
20 * 9.5 + 25
20 * 8.5 + 25
Now the rear fit snug as a bug in a rug, just teasing their lip out of my lightly pumped guards.
Issues arise with the front however. The rolling diarmeter of the rim seems too large for an R33 to cope with.
The tire in the pics is a 245/40/20... so I am intending to run a 225/30/20 with some stretch to pull the rolling diameter back abit. That said, the 245's on the rim are worn to the belts and therefore I am skepcital of how a 225 will go with full tread, considering this worn out 245 still rubs.
Now, I was considering a 10mm spacer to pull the inside of the tire away from the control arm, AND a 225/30/20 with abit of stretch in the side wall to increase the gap. However, I'm not sure it will be enough.
Has anyone else run into these issues with stupid 20s? Suggestions? Does anyone know if aftermarket control arms are available (I had a quick look, but didnt see anything)
Pics of my problem....
https://www.sau.com.au/forums/topic/347707-20-inch-wheels-on-r33-work-meisters/
dont run 20's? ;)
seriously tho, spacers are gonna be your only option....
if you go 20mm bolt on up front you'll have clearance and 30mm bolt on rear then pull the guards it'll look even again... this will take work and cost a lil :/
Hmmmm. It appears 225/30/20s only increase the rolling diameter by 11mm over the standard 225/50/R16 rolling diameter of the 33. If I add in some stretch and some spacer-age... and I think it might just fit.
Haha I know this will cop "dont put 20s on a 33"... but they came up so I snapped em up. Sort the fitment out at a later stage :P
20 * 9.5 + 25
20 * 8.5 + 25
Judging by the pictures you posted and the overall diameter of your current tyres you shouldnt need bolt on spacers to make the front wheels fit.
Here are the approximate overall diameter's of the tyres you have and alternatives that could get you out of trouble (factoring in tread depth which is usually about 5-7mm depending on the tyre).
245/40R20 - approx O.D: 704 - 705mm
245/35R20 - approx O.D: 679 - 680mm = -24, -25mm (compared to 245/40)
225/35R20 - approx O.D: 665 - 666mm = -38, -39mm (compared to 245/40)
225/30R20 - approx O.D: 642 - 643mm = -61, -62mm (compared to 245/40)
One thing you will have to be aware of is that as a general rule the lower you go in sidewall, the lower the tyre's load rating and if the load rating isnt equal to or higher than the manufacturer's spec then you can be defected or if you have an accident your insurance can be void... So make sure you check the load ratings before fitting new tyres.
I hope this helps :)
P.S - Love the Work Meister S1's! :thumbsup:
U can also get defected for having a total diameter over 15mm over stock so you pretty much can't win with 20's. I'd prefer to have the correct outer diameter than the correct load rating.
Should've got 22's for your 33 :P
On a serious note though, grinding down the upper arm worked for me, had the car pretty low and it scraped on full lock. Another option is to just get yourself some adjustable coilovers and raise the front up by 10-20mm. Won't have a huge impact on the look of the car.
Spaces draw unwanted attention so I'd steer clear of them.
I do have Teins in the car... so once I get the wheel clearing I will play with ride height to make em not scrub on the guards.
I am hesitant about griding the control arm. I know in reality its an easy fix but its abit of a last resort for me.
I will run 225/30 tires on the front, and I am hoping this will provide the clearance I require. Will keep you guys updated!
i personally wouldnt touch the control arm. who knows how much that is going to affect the integrity of the arm + what if you get defected? would they knock you for that? could mean a new control arm...
thought i wouldnt be able to say this but it looks fkn sweet tho mate, tuff as nails
Thanks!
Haha yeh everyone hears 20s and thinks "GAY".
Thats ok i generally do to. But I must admit, these 20s I couldnt resist. There is something stupidly attractive about the proposition of black 20inch meisters on my car.
Im going for a new look, so the wing will be coming off and replaced with some carbon fibre touches here and there :D
20s look stupid on the front of skylines the lack of tyre sidewall and the raised hieght is ridiculous..
Now if your were to pick up some 18s for the front,it will make your steering easier and better, it will make your your frontend lower giving the car a mean rake with the front being slightly lower than the rear and generally all your problems will be solved and your car will look tuff as balls..
Thats my 2c anyway ,if you wanna keep your stupid 20s on the front then i have no further advice..
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
