Thanks for the responses to my questions/comments :)
I didnt actually realise the T67 wasnt a Twin Scroll turbo, but I do know the fact that you need to have both turbo/manifold as twin scroll items. Well, it seems I'll have to go with the T67 regardless, as my previous 'budget' just got hammered due to a family member requiring medical bills paid. Oh well. So, just to clarify, the T67 or the SH should both be 300+rwkw quite easily? With supporting mods? I think I got that part right :)
Yeah mate, T67 is 300kw all day long.
Arthur, to publicly clarify the TD06SL2 20g is a 300kw item on SR's and Evo's.
I'm sure thats on E85 and well sorted motors, but I'm not talking about hens teeth to find. NS.com and evolutionoz both have plenty of testament in the way of dyno sheets.
Stop doubting your purchase! LOL
WTF!!! I didn't even get a sticker! feel so cheated :(
:D want some stickers?? i have some on the way. i sent an email to kando dynamics, and asked for some promotional stickers for us all, They were more than happy to help. heres the reply.
Dear Man,
Thanks for using Kinugawa turbocharger and like to promote this good product in Australia.
I will make the stickers for you all asap.
Do you mind leave your address that I can send some to you.
Regards
Eiji Takada
so i have sent my address, and once i recieve some, ill let u all know, get some details off the poeple that want them... simon, battery, arthur.. and others, depending on how many come in the mail(i asked for around 10) :D
Edited by OMY31T
Haha who is a hater? The results are very close to garret for half the price, I can't imagine anyone hates that! jealous maybe not but hate! :)
All the people who paid over double for their turbo and make less power and response... and have slower cars :nyaanyaa:
I for one have had my GT3076R since WAY before I was aware of Kinugawa turbos, would freely admit a T67 is as responsive if I drove a car running one and found it to be the case. I also got my GT3076R for ~$2000nzd, the cheapest I can get a Kando T67 landed is $1400-1500nzd which I'd have needed an exhaust manifold, external wastegate and a bunch of other custom work to get installed. I have less power than people are making with T67s, a large part of that is to do with supporting mods, normal 98 petrol and the fact I just haven't bothered pushing it that hard. So far the highest I've seen anyone making on a GT3076R and a T67 is pretty much equal, so while I'm definitely not going to flame T67s - I think its basically retarded to bag the Garrett GT-series seeing as they've been around so much longer and are proven to all f**k.
If I were to do it all again now I'd personally go a Holset HX35 over a T67.
BTW, heres a recently installed Kinugawa T67 I referred to looking forward to the results from a bit earlier in the thread. It handled being started and a couple of quick boosts before compressor wheel met compressor housing, the turbo has been disassembled to check for oil starvation or any other installation related issues and it basically seems that one got through QC. Or something.
Who bagged a GT series Garrett?
I have never seen a turbo have that kind of damage from hitting a compressor housing, they normally just wear down the wheels... Have seen a lot of turbos like that which have eaten bolts/stones etc. so my question is what did it eat?
That looks more like something got through the filter, like a loose bolt or something! I would be pulling the entire intake assembly out to look for it imo.
I had a turbo where the housing and compressor made love, it still boosted but it sounded like a jet engine, probably the loudest whining noise I've ever heard, and yeah it just ground the edges down every so slightly, didn't snap anything off.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
