Scott, thanks, I do now understand the concept of an external gate setup, and hell no, I'm not going to have an open screamer and hence a massive fine and defect, it will have to plumb back onto my dump, and either collect the gases out from my stock manifold or turbo rear housing - I dunno which is easier /cheaper /more preferred..
Is it sad that I now dont want one of these turbos because everyone buying them is doing it as cheap as possible.
I am now waiting for all the threads/comments saying my car isnt performing like Simon-R32's car etc
modded the stock manifold to suit 44mm v-band ext gate, running either a tial mvr or turbosmart hyper gate
Did you keep the standard splitter inside the manifold when you modded it for external gate? If you didn't I would recommend that you ditch it, get a new one and weld gate to rear housing!
Guys asking about gates, I think Tial 44mm MVR off ebay for $400 is a bargain and you can't go wrong :thumbsup:
Make sure you have your labour aspect of things well sorted and know the implications of a screamer (if you opt to go that way) or how standout your setup will be to NSW highway patrol.
On a dedicated street car this is why the HG wins everytime no matter the cost.
Never fear, I'll chuck some cams and springs in my car this year and try for some more power to keep the pundits happy :whistling:
Ur a pretty sad bloke Zebra, not surprising seeing as u from ACT...pinch.gif
Will it please you if I go mount my Wastegate on my dump pipe?
oh no you didnt...
yeah MVR gate on ebay was the cheapast i saw $410 del (that seller is away till 8/1/12 btw) then next is $440 @ powertune.com.au
i got mine second hand.for $300 del.
BSA is doing the mod to the manifold for me, his pics are below of the one he did on his car and looks like the standard splitter is still in place :thumbsup:
The thing that worries me with gate on manifold is police/ pits if you get a sticker and need to go over pits to go back to standard turbo you need another manifold if it on housing pull off turbo bolt on stock turbo get a basic tune take over pits done easy as
LOL somehow I don't think you are quite knowledgeable enough to make a comment
Since you are so clever stripey horse, I will tell you why I dont like the idea of welding onto the stock manifold - luvpsi above said it for me..
If you have fresh studs that are <10,000kms do they snap just as easily?
Reason I ask is I took my manifold and turbo off twice with the same studs and had no issues, they were all under 10,000k though. Was running 18psi on a highflow so would have gotten bloody hot as well.
Edited by Rolls
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
