Scott, thanks, I do now understand the concept of an external gate setup, and hell no, I'm not going to have an open screamer and hence a massive fine and defect, it will have to plumb back onto my dump, and either collect the gases out from my stock manifold or turbo rear housing - I dunno which is easier /cheaper /more preferred..
Is it sad that I now dont want one of these turbos because everyone buying them is doing it as cheap as possible.
I am now waiting for all the threads/comments saying my car isnt performing like Simon-R32's car etc
modded the stock manifold to suit 44mm v-band ext gate, running either a tial mvr or turbosmart hyper gate
Did you keep the standard splitter inside the manifold when you modded it for external gate? If you didn't I would recommend that you ditch it, get a new one and weld gate to rear housing!
Guys asking about gates, I think Tial 44mm MVR off ebay for $400 is a bargain and you can't go wrong :thumbsup:
Make sure you have your labour aspect of things well sorted and know the implications of a screamer (if you opt to go that way) or how standout your setup will be to NSW highway patrol.
On a dedicated street car this is why the HG wins everytime no matter the cost.
Never fear, I'll chuck some cams and springs in my car this year and try for some more power to keep the pundits happy :whistling:
Ur a pretty sad bloke Zebra, not surprising seeing as u from ACT...pinch.gif
Will it please you if I go mount my Wastegate on my dump pipe?
oh no you didnt...
yeah MVR gate on ebay was the cheapast i saw $410 del (that seller is away till 8/1/12 btw) then next is $440 @ powertune.com.au
i got mine second hand.for $300 del.
BSA is doing the mod to the manifold for me, his pics are below of the one he did on his car and looks like the standard splitter is still in place :thumbsup:
The thing that worries me with gate on manifold is police/ pits if you get a sticker and need to go over pits to go back to standard turbo you need another manifold if it on housing pull off turbo bolt on stock turbo get a basic tune take over pits done easy as
LOL somehow I don't think you are quite knowledgeable enough to make a comment
Since you are so clever stripey horse, I will tell you why I dont like the idea of welding onto the stock manifold - luvpsi above said it for me..
If you have fresh studs that are <10,000kms do they snap just as easily?
Reason I ask is I took my manifold and turbo off twice with the same studs and had no issues, they were all under 10,000k though. Was running 18psi on a highflow so would have gotten bloody hot as well.
Edited by Rolls
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
