10x1.25 iirc and about 65mm long I am told
Yep. Although with a 15mm spacer I used 57mm studs and they have plenty of room, so unless you need a 20mm spacer I'd say 65mm would be a bit long. Unless the Kando flange is thicker than the HG flange, I don't know.
hmmm
will send pm in a min
not ready to buy yet
will buy one of these first
http://www.summitrac...-2046/?rtype=10
to be 100% happy on the way it fits
Your going to spend 400 bucks on a foam LS1 to see if it fits?
LOL
dude its a commondoor motor... Why not go on a common forum and look for a blown one for $50
thanks guys
ARTZ, did you use a 10/15/20mm flange spacer?
found that ARTZ used a 10mm spacer and it "just" cleared.
might go 15mm for peace of mind.
so new update part list:
10-15mm spacer (up to you what size you want to get) $30
new exhaust manifold studs & nuts x12 ea (if needed) $110~ (nissan) or generic stuff from local exhaust place ($50~) - this is optional but if you break a stud or round one, you will need to replace them but it is a good thing to replace them all anyway and is cheap insurance that your studs won't break or round.
Dori you should do a DIY thread with pics for a 20g 10cm and document your results. Itd be nice to see the bare minimum done to fit one up, and documented for all to see.
good idea,
i shall get started after the new year once i get all the parts.
cars booked in for 16th Jan.
thanks guys
10mm
jeez man i have documented nearly my whole build in here...
what would u like that i have not provided :(
BITCH!!!
Car went great at drifting yesterday.
Only issue's i had was a busted radiator from the fan coming in contact (.5mm contact) , i popped the cooler pipe off twice. And i need a tighter diff centre. The GTR one just kept going open.
Other than that was a great day out. This turbo is very nice to drive with. On song hard by 4000rpm all the way to limiter at 7400. I will definately be fixing up the vct and tuning it to 18psi. At the moment with no boost controller and a tiny 35mm turbosmart gate it starts at 11psi and climbs to 17 by redline, starts getting crazy at 17.
I'll post up some incar vids once i get them off the GoPro
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
