10x1.25 iirc and about 65mm long I am told
Yep. Although with a 15mm spacer I used 57mm studs and they have plenty of room, so unless you need a 20mm spacer I'd say 65mm would be a bit long. Unless the Kando flange is thicker than the HG flange, I don't know.
hmmm
will send pm in a min
not ready to buy yet
will buy one of these first
http://www.summitrac...-2046/?rtype=10
to be 100% happy on the way it fits
Your going to spend 400 bucks on a foam LS1 to see if it fits?
LOL
dude its a commondoor motor... Why not go on a common forum and look for a blown one for $50
thanks guys
ARTZ, did you use a 10/15/20mm flange spacer?
found that ARTZ used a 10mm spacer and it "just" cleared.
might go 15mm for peace of mind.
so new update part list:
10-15mm spacer (up to you what size you want to get) $30
new exhaust manifold studs & nuts x12 ea (if needed) $110~ (nissan) or generic stuff from local exhaust place ($50~) - this is optional but if you break a stud or round one, you will need to replace them but it is a good thing to replace them all anyway and is cheap insurance that your studs won't break or round.
Dori you should do a DIY thread with pics for a 20g 10cm and document your results. Itd be nice to see the bare minimum done to fit one up, and documented for all to see.
good idea,
i shall get started after the new year once i get all the parts.
cars booked in for 16th Jan.
thanks guys
10mm
jeez man i have documented nearly my whole build in here...
what would u like that i have not provided :(
BITCH!!!
Car went great at drifting yesterday.
Only issue's i had was a busted radiator from the fan coming in contact (.5mm contact) , i popped the cooler pipe off twice. And i need a tighter diff centre. The GTR one just kept going open.
Other than that was a great day out. This turbo is very nice to drive with. On song hard by 4000rpm all the way to limiter at 7400. I will definately be fixing up the vct and tuning it to 18psi. At the moment with no boost controller and a tiny 35mm turbosmart gate it starts at 11psi and climbs to 17 by redline, starts getting crazy at 17.
I'll post up some incar vids once i get them off the GoPro
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
