Because the boost falls over at the top it seems inconsistant with boost creep as creep should keep climbing all the way to redline. But 38mm is right on the limit.
What im saying is use te boost controller to try and run 18psi solid from 4 to redline. If he had not control at all with the boost then the boost controller lines are back to front
I see what you mean. Ill get it sorted one way or the other soon.
Once i sort it out i hope it comes on earlier too.
So i wouldnt get the results I am after with that turbo?
For an internally gated turbo you would definitely get a better result from a Hypergear :)
For your power goal of 230-250 I recommend you get a Hypergear highflow, it is a simple rebuild/respec of the standard turbo that will get you the results your after.
That being said, it will also bolt straight back on where you took it off (stao will provide you with the extra bits needed to make it direct fit). Its also cheap, only something like $960 delivered and ready to bolt on.
Confused reader here. I have a pretty much stock R33 S2. All I've done so far is 3" from turbo back exhaust, mounted an ARC return flow intercooler, installed a cheapy Drift pod filter and grounded the boost wire. I've also installed a Walbro fuel pump. I'd love to get more boost happening and understand I'd need to get a different turbo. Hypergear sounds like it could be for me as it's direct bolt on. Then get a nistune board installed and get it all tuned on the dyno. At that state, what HP or KW do you guys think I'd getting? I don't have plans to go as extreme as some guys here, God bless them, so think a high flow and nistune and I guess new coil packs (will I need new injectors too?) is about my end game, plus at some point replacing my stock shocks.
My advice is to get the ECU first. Also, if you are considering buying a HG turbo, Stao can give you a great deal on an Adaptronic plug in ECU. Something to think about given you have an R33, so the NIStune will take some messing around. The Adaptronic may represent better value for money. Perhaps look into it?
Then, it depends which turbo you end up getting from HG as to what HP you can expect and whether you will need injectors. If you go a simple highflow, stock injectors mayyy be able to do the job, perhaps with a bit of help from an aftermarket fuel pressure regulator. They will be very close to maxed in any case. However if you want something capable of say 250rwkw, then you're probably going to have to do injectors as well. I'd suggest talking to Stao about what you want.
Edited by Hanaldo
Sounds good until the adapteonic ecu is $1500 plus tuning instead of the $1350 supplied fitted and tuned including z32 ecu for nistune
Not if he buys the HG turbo. Stao quoted me $1040 delivered for the Adaptronic.
Plus tuning. I agree it is a good price but nothing can beat NIStunes for cost.
Tis true, the NIStune is a good option I agree. Just food for thought.
How much would you charge to do the Adaptronic? I was quoted $650-$750 to install/tune my Link plug in. Also have to factor in IAT sensor. So if the Adaptronic is similar, then you're looking at what, $1800 installed, tuned, everything? If the NIStune is $1350 tuned, and the OP decided he wanted more power and needed to get the Z32 AFM as well, that makes it between $1600-$1800? Depending on the price of the Z32 as well as installation, etc.
And that's only if he decides to get the Z32 done at the same time as everything else, if he changed his mind later and needed to get it done then that adds another $400 or so for a retune? Whatever way you spin it, the NIStune is probably going to be the cheaper option. But if it's only ~$200 cheaper...
Edited by Hanaldo
Be it myself Id probably take up the offer on the HG and adaptronic, as it takes away another expense (AFM) as stated and one less thing to compensate for when making intake pipes and all that crap.
Id personally like to own an R33 which had a HG H/F, adaptronic, TBE, pump, fmic. Id leave the stock injectors in there and run it at the quoted 15psi. Should go really well.
U are spot on. Thats why i try to convince most customers to do everything at once then to keep adding parts that require a retune. Costs more up front but saves alot down the track
That's exactly what I'm trying to tell myself about getting the Link installed now, rather than later. The soreness of the wallet makes it a bit hard though :glare:
Except when the minimum boost it will run is 18psi. Ask Mitcho. I dont feel its safe to try max the injectors out and leave them running like that.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
