Because the boost falls over at the top it seems inconsistant with boost creep as creep should keep climbing all the way to redline. But 38mm is right on the limit.
What im saying is use te boost controller to try and run 18psi solid from 4 to redline. If he had not control at all with the boost then the boost controller lines are back to front
I see what you mean. Ill get it sorted one way or the other soon.
Once i sort it out i hope it comes on earlier too.
So i wouldnt get the results I am after with that turbo?
For an internally gated turbo you would definitely get a better result from a Hypergear :)
For your power goal of 230-250 I recommend you get a Hypergear highflow, it is a simple rebuild/respec of the standard turbo that will get you the results your after.
That being said, it will also bolt straight back on where you took it off (stao will provide you with the extra bits needed to make it direct fit). Its also cheap, only something like $960 delivered and ready to bolt on.
Confused reader here. I have a pretty much stock R33 S2. All I've done so far is 3" from turbo back exhaust, mounted an ARC return flow intercooler, installed a cheapy Drift pod filter and grounded the boost wire. I've also installed a Walbro fuel pump. I'd love to get more boost happening and understand I'd need to get a different turbo. Hypergear sounds like it could be for me as it's direct bolt on. Then get a nistune board installed and get it all tuned on the dyno. At that state, what HP or KW do you guys think I'd getting? I don't have plans to go as extreme as some guys here, God bless them, so think a high flow and nistune and I guess new coil packs (will I need new injectors too?) is about my end game, plus at some point replacing my stock shocks.
My advice is to get the ECU first. Also, if you are considering buying a HG turbo, Stao can give you a great deal on an Adaptronic plug in ECU. Something to think about given you have an R33, so the NIStune will take some messing around. The Adaptronic may represent better value for money. Perhaps look into it?
Then, it depends which turbo you end up getting from HG as to what HP you can expect and whether you will need injectors. If you go a simple highflow, stock injectors mayyy be able to do the job, perhaps with a bit of help from an aftermarket fuel pressure regulator. They will be very close to maxed in any case. However if you want something capable of say 250rwkw, then you're probably going to have to do injectors as well. I'd suggest talking to Stao about what you want.
Edited by Hanaldo
Sounds good until the adapteonic ecu is $1500 plus tuning instead of the $1350 supplied fitted and tuned including z32 ecu for nistune
Not if he buys the HG turbo. Stao quoted me $1040 delivered for the Adaptronic.
Plus tuning. I agree it is a good price but nothing can beat NIStunes for cost.
Tis true, the NIStune is a good option I agree. Just food for thought.
How much would you charge to do the Adaptronic? I was quoted $650-$750 to install/tune my Link plug in. Also have to factor in IAT sensor. So if the Adaptronic is similar, then you're looking at what, $1800 installed, tuned, everything? If the NIStune is $1350 tuned, and the OP decided he wanted more power and needed to get the Z32 AFM as well, that makes it between $1600-$1800? Depending on the price of the Z32 as well as installation, etc.
And that's only if he decides to get the Z32 done at the same time as everything else, if he changed his mind later and needed to get it done then that adds another $400 or so for a retune? Whatever way you spin it, the NIStune is probably going to be the cheaper option. But if it's only ~$200 cheaper...
Edited by Hanaldo
Be it myself Id probably take up the offer on the HG and adaptronic, as it takes away another expense (AFM) as stated and one less thing to compensate for when making intake pipes and all that crap.
Id personally like to own an R33 which had a HG H/F, adaptronic, TBE, pump, fmic. Id leave the stock injectors in there and run it at the quoted 15psi. Should go really well.
U are spot on. Thats why i try to convince most customers to do everything at once then to keep adding parts that require a retune. Costs more up front but saves alot down the track
That's exactly what I'm trying to tell myself about getting the Link installed now, rather than later. The soreness of the wallet makes it a bit hard though :glare:
Except when the minimum boost it will run is 18psi. Ask Mitcho. I dont feel its safe to try max the injectors out and leave them running like that.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
