Stock airbox could lose you 5-10kw nothing to significant, i am thinking of adding a pod out the bottom of it as well through the unused intercooler hole .But the power delivery I find is different, it comes on smoother so full boost doesn't hit quite so hard, its a little more transient.. Also Trent set the gate up to ease onto boost which smoothed it out some more.. Change this and stick a pod on and I have no doubt boost would hit like a hammer.. Depends which you prefer I guess and this is the way i wanted it
My timing belt has about 60k on it now I will do cam gears when I change it..might give the Brae manifold a go to then too..For now i just want to enjoy driving it for a while. :D
ahhhhhhh cheers for the heads up. Yours really is close to the manifold. I'm pretty sure I can get my gate up a fair bit closer to the manifold. if not whats your feeling on me replacing the 40mm pipe with say a 50mm pipe while still using a 40mm gate.
I would have thought that a 40mm gate was too small for the application. I have a 44mm one with a smaller turbo and engine and it's probably only just up to the task. I would be looking at least at a 44mm or 50/60mm plus a larger pipe feeding it as you suggested.
hey urtwhistle, FWIW my 6boost has the gate just inches off the collector and points maybe 2 or 3 degrees northward (i suspect they do that to promote flow going towards the gate).
yours is both long and looks like it doesnt point up at all, just straight down. id say work on that, but i dont feel the comp 40 will hold you back at this stage
can u fit the td05 in the stock turbo position?
and ive got one of those china split dump screamers (havnt used it yet) could i just run an internal gate td05 with this so i dont even need a wastegate?
ill re phrase that for you, the TD05 can bolt up to the stock manifold (with a small spacer) they are the same flange type (T3 open).
the existing dump will be useless regardless of what Kando option you decide on... you will need to make a new dump and if you want the best results you will also want to use an external gate.
if you are thinking you want to keep things as bolt on as possible, you should really be looking at the hypergear thread. he also gets excellent results from his turbo, and picking one of these over his is usually only an interest factor. you could get out of it a lot cheaper if you just stick to hypergear.
maybe consider sending your stock turbo to him and having it rebuilt to suit the exact power you want.
I dont need it to stay stock, was just seeing what i can get away with. I don't mind going high mount if need be, ill just evaluate it when the time comes. cheers for all you're help.
Nice work Artz! would be interesting to take a ride in each others cars one day.
My gate pipe comes off the 6boost and turns like 130-140 degrees, the pipe is 300-400mm long, gate sits next to the PS rack. Definitely not an ideal setup if you go off all the recommendations in here but it controls boost perfectly..
Who cares... Just tune your billet wheel :whistling:
Ok guys, for those that are interested I got my Kelway manifold today so here are a few pics.
He makes his own collector, he doesn't buy the pre made one.
Nice looking manifold. I wouldnt be fussed whether he makes his own collector or buys them, I just want someone to make one out of tube. Then we see how well they are fabricated and welded and it will be half the weight :)
Nope
By tube I assume you mean the material like used in s/steel manifolds? If so I'd rather the weight of steam pipe any day for its strength and ability to hold in more heat in comparison.
Think hes more referring to the thickness??? steam pipe is forgiving cause if your fab work is second rate you can just hammer it with the die grinder a luxury you don't get when working with 1.6/2mm tube... what wall thickness are the greddy manifolds Roy?
anyone know why my idle keeps bouncing between 1500-2000 whenever i pull up at the lights :unsure:
it will settle after a bit (2-3 minutes maybe) but its got me stuffed, Trents been stuffing with it tune half the day but it still there, figure it must be something mechanical..AAC valve or a leak maybe..
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
