the way i worked it out was its probably revving to about 7000, maybe a bit less like most ppl do...
the graph doesnt show RPM but it does show rod speed.. so if 180kmh is close to 7000, 90kmh is close to 3500.
its a few rpm off but close enough, boost is definitely well and truly on before 4000. a good achievement.
no way 3500 is 90km :no:
Anyway out of curiosity and boredom I just laid my dyno sheet next to battery's..
Im sure many of you have done this already.. but im posting it.. :D
Not alot in it really, they are running almost identical boost , I have a fair bit more midrange torque and an extra 20kws at 5k, but nose over after 6k where they are both pulling 300kws,
Then he keeps pulling past 7 and smashes me..
Just remembering though I have alot less mods under the bonnet <<read excuse for losing... :Pbatterydynosheet.jpgtune300.jpg
Im not gunna bother comparing anything to Simons freak of nature....
well know how many revs it is if we know where the run ends.. speed and RPM are always relative. you will do double the speed at double the revs in the same gear etc.
nice comparo too :) i cant wait to pop a 20G on my SR
Aaww don't be sad Simon you know your my hero.
Its more the fact I can't be bothered converting all your dynosheet figures to something legible. :laugh:
I think u were making the same as me at 5Ooorpm
On low boost mine is about the same as yours at 5000rpm, high boost close to 30kw more
You guys need to screw more boost in... 2bar or bust :)
Edited by SimonR32
Yeah you can see my 20g making more on the green line but that was 21.5 psi which is 4psi more than the blue line and the gains were insignificant..As Roy said the little comp just can't push any harder ,its giving all she can give..especially on my setup..If I get a better manifold and plazmaman plenum and better cooler it could possibly push for a little more.. But looking at the comparison I would sooner just get a T67 than push this any further.
Not sure why battery didn't push more in..
Got a scanner Artz? I think I could use my broken ass Photoshop skills to overlay onto the same image..
Just re did all my cooler piping in 2.5"(was a mix of 2.25/2.5" before) and now i'm thinking maybe I should move to a bigger Throttle body, not sure if there is much point cause the stock one is still bigger than the 2.5" piping ??
Haha I was putting mine over a picture of yours on the computer, I was gunna trace it but gave up..its almost identical though with yours just dipping a Little between 4-6rpm
That's the same size as my cooler piping I guess there is hope for it yet :D
Got my T67 today and have a few questions.
It came with a 4" Anti surge compressor housing which i did not want i wanted a standard 4" Compressor housing. Will this matter that much?
What is the best way to block the water lines? The shorter of the 2 (Water return??) I was simply going to find a bolt wth the same pattern but shorter and bolt it in nice and tight with a coper washer.
Not sure what to do with the one that goes around the back of the block should i just cut it off shorter and fix a blocked off bit of hose on the other side? Or blank it off at the source, which im guessing is under the plenum?
Any help is appriciated keen to get her back together, tonight i have connected oil feed(One supplied with the turbo is a bit long) and return. Finished replacing exhaust manifold studds.
Also I have one of those NZ manifolds and i am not happy with the way the wastegate pipe comes out it is really really close to the body and air con lines.
Should i modify this pipe or just blank it off and run the gate off the turbin housing?
is this one of the mild steel ones from ebay? i was pretty keen to get one of these for my rb20 anymore negatives?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
