the way i worked it out was its probably revving to about 7000, maybe a bit less like most ppl do...
the graph doesnt show RPM but it does show rod speed.. so if 180kmh is close to 7000, 90kmh is close to 3500.
its a few rpm off but close enough, boost is definitely well and truly on before 4000. a good achievement.
no way 3500 is 90km :no:
Anyway out of curiosity and boredom I just laid my dyno sheet next to battery's..
Im sure many of you have done this already.. but im posting it.. :D
Not alot in it really, they are running almost identical boost , I have a fair bit more midrange torque and an extra 20kws at 5k, but nose over after 6k where they are both pulling 300kws,
Then he keeps pulling past 7 and smashes me..
Just remembering though I have alot less mods under the bonnet <<read excuse for losing... :Pbatterydynosheet.jpgtune300.jpg
Im not gunna bother comparing anything to Simons freak of nature....
well know how many revs it is if we know where the run ends.. speed and RPM are always relative. you will do double the speed at double the revs in the same gear etc.
nice comparo too :) i cant wait to pop a 20G on my SR
Aaww don't be sad Simon you know your my hero.
Its more the fact I can't be bothered converting all your dynosheet figures to something legible. :laugh:
I think u were making the same as me at 5Ooorpm
On low boost mine is about the same as yours at 5000rpm, high boost close to 30kw more
You guys need to screw more boost in... 2bar or bust :)
Edited by SimonR32
Yeah you can see my 20g making more on the green line but that was 21.5 psi which is 4psi more than the blue line and the gains were insignificant..As Roy said the little comp just can't push any harder ,its giving all she can give..especially on my setup..If I get a better manifold and plazmaman plenum and better cooler it could possibly push for a little more.. But looking at the comparison I would sooner just get a T67 than push this any further.
Not sure why battery didn't push more in..
Got a scanner Artz? I think I could use my broken ass Photoshop skills to overlay onto the same image..
Just re did all my cooler piping in 2.5"(was a mix of 2.25/2.5" before) and now i'm thinking maybe I should move to a bigger Throttle body, not sure if there is much point cause the stock one is still bigger than the 2.5" piping ??
Haha I was putting mine over a picture of yours on the computer, I was gunna trace it but gave up..its almost identical though with yours just dipping a Little between 4-6rpm
That's the same size as my cooler piping I guess there is hope for it yet :D
Got my T67 today and have a few questions.
It came with a 4" Anti surge compressor housing which i did not want i wanted a standard 4" Compressor housing. Will this matter that much?
What is the best way to block the water lines? The shorter of the 2 (Water return??) I was simply going to find a bolt wth the same pattern but shorter and bolt it in nice and tight with a coper washer.
Not sure what to do with the one that goes around the back of the block should i just cut it off shorter and fix a blocked off bit of hose on the other side? Or blank it off at the source, which im guessing is under the plenum?
Any help is appriciated keen to get her back together, tonight i have connected oil feed(One supplied with the turbo is a bit long) and return. Finished replacing exhaust manifold studds.
Also I have one of those NZ manifolds and i am not happy with the way the wastegate pipe comes out it is really really close to the body and air con lines.
Should i modify this pipe or just blank it off and run the gate off the turbin housing?
is this one of the mild steel ones from ebay? i was pretty keen to get one of these for my rb20 anymore negatives?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
