Thanks bling.
Its not that the T67 is bad, it just seems that it is choking the engine. Super early spool and a drop off at high revs.
I sent a message to Kando too. He says he doesn't have a 12cm for the T67. So it looks like I'm sticking with what I've got for a while anyway, at least till have money for another turbo at some point.
do the anti surge front covers not perform well?i have a kando td06 sl2 20g with a 8cm rear that i am putting in my r33 at the moment.i was looking for a 10cm rear and contacted kando and they said i would have to buy it seperate.but i got the turbo and tial 44mm mvr wastegate brand new for dirt cheap so i couldnt let it go.just hoping the anti surge cover wont cause any problems
You can get the housings separate, exhaust side is about 150 and intake is less.
Mook it might be worth you just getting 2 housings and giving it a go. Assuming antisurge might be an issue and it might be an 8cm.
You can use boost pressure to help hold the wastegate shut. Definitely worthwhile.
I finally got my Kinagawa actuator, I asked for the extra nipple but didn't get one! I might be able to find something with the right thread to suit though.
The actuator itself looks very good.
We have the car on track today and my exhaust temps are through the roof. Melting the tar on the floor inside and the carpet and the mat on the carpet. So guessing the housing is way too small.
Andy, Do you have any pics of your 10cm housing for me to compare to mine please
This can be from the tune also
Thanks for the pics guys, my housing looks pretty dam close to the ones in the pics, so i think it may be a 10cm
What in the tune can cause so much heat??? I dont mean to sound like a smart ass there, i honestly dont know
ARTZ, i dont think so, i dialed the cams in when i assembled the engine and they are within 1/2 degree of the factory settings.
My car blows fireballs the size of a car so i dont think its running lean, :yes:
I backed the boost off to around 16psi from 22 to control the heat, it was stupid hot at winton this weekend. It did make a difference, as it should.
Edited by MookRG
No cat, does have a straight through muffler and a res though,
The AFR's were a little rich on the dyno, not heaps just a little to be safe, from memory they were around low 12's high 11's i think. I'm pretty tired from the weekend, i could be wrong i will check later today gonna go see my tuner.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
