Been reading up on these turbos lately and looking at a TD06 20G with the 10cm rear EG for my 33 RB25 with the following mods.
The normal cooler and exhaust etc
Tomei pon cams with gears
550cc injectors
Power fc
Freddy manifold
Lightened flywheel with a 6 puck button clutch that im going to sell and buy a more capable one
Surge tank, oil cooling, bigger radiator etc all done.
But what I really want to know is has anyone low mounted one of these, more so on a GTSR manifold? As I have read that some of the compressor housings are pretty large is this the case with the TD06 item?
What are peoples thoughts on welding the gate on the exhaust housing as I don't want to ruin the manifold?
Also to be annoying the normal question of coming on boost, full boost and rough power out put?
Sorry if it seems like a noobs post but I would like to know before I go out and buy one if its capable with my manifold on 25 in my hr31 coupe?
Thanks
United 100 (still pump fuel), 550 Nismos, Nistune, Walbro, Cooler, Exhaust...Thats its basically
Wow, stout - got to be happy with that! Nice work, and its nice to know it's capable of that kind of performance :)
550cc injectors
Power fc
Freddy manifold
Thanks
ARTZ lowmounted that turbo on a stock manifold, and one other member also did before having to sell the car (IIRC). Both members results were within reasonable difference. 14-16psi 260rwkw on 98, 300kw on E85, good response all round.
I can understand the thread is 270 pages wrong but this has been talked about so many times....
Furthermore the Hypergear SS2 does not give much away in response and has significantly higher power limits. Please read both threads.
Is it comparably priced?
I believe it to be better value.
A current model SS2 type B with IWG should cost the 1200 mark IIRC.
For most people who already sport a 3" dump that saves them on the cost of an EWG, plumbing it up and fabricating a dump. Say 700 kando, 400 gate, 300 to cast weld gate to manifold, 400 for dump and screamer... I think those prices are conservative and rounded down in most cases.
Not trying to product push, am just a mad stalker of both threads and hold an opinion on the matter.
Why does it need to be an external gate one? To me this seems like something which could be a bit of fun...
http://www.ebay.com.au/itm/Upgrade-Turbocharger-RB20DET-RB25DET-w-Stage-3-Turbine-68mm-Comp-450BHP-/281117739250?pt=AU_Car_Parts_Accessories&hash=item4173ec48f2
Or even this if there is any doubts about the stock compressor housing flow:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-RB20DET-RB25DET-TD06-20G-T3-8cm-V-Band-/271219785633?pt=AU_Car_Parts_Accessories&hash=item3f25f57fa1
From our testing so far, the Kando anti-surge/lag thing is bollux - we are very impressed with the internally gated bolt on anti-surge Kando so far. Boost holds 19psi perfect with electronic boost control, or 10psi without creep on wastegate boost which leaves heaps of room for us to sort out boost-per gear with a wide range. Very much looking forward to seeing how it behaves on the dyno.
I have read that all the kando internal gate ones aren't very good with boost control. I haven't seen any decent results with the internal ones.
Clearly I was lying then, I'll stop feeding this thread with BS and leave you guys to turn it into a Hypergear thread, as well as the FP thread, and I think the Precision thread is also lacking in Hypergear propaganda too :P
OH YEAH! I forgot about the re-production 2iu housings.. I hadn't eve thought to look for that on eBay.
I may speak to a friend about trying one of these, though I would prefer an L2 18G in the stock housings. Roy has explored the 20G 8cm realms but I am not confident its everyones cup of tea (on an RB25).
I'm keen to see your anti-surge final results dude, am always happy to take on new data and concepts. At the moment the general consensus was that it was laggier, but that could be a different story on the smaller compressor housings or wheels (remembering yours is the 3" .60 housing with a 20G wheel and most feedback was based on the 4" .70 with 25G wheel).
The one dude who did 'back to back' a 20G 3" anti-surge was not convinced the non surge cover was actually the fix. Hopefully your friends one can at least settle the debate on the 3" cover.
8cm rear is too small for my liking. I have read that all the kando internal gate ones aren't very good with boost control. I haven't seen any decent results with the internal ones.
The MHI style housings are total dogs balls, but those 2iu style ones are probably fine. Hypergear is importing a similar housing which I'm sure comes from the same foundry.
So it should work fine, depending on what size flapper Kando are installing and the balance of flow from the wheels. If you have a read of the Hypergear threads (will take you a year) it took him a while to get the balance of wheels and WG flapper right. The current standard highflow is a good thing.
Dont have a dyno sheet on me atm as im away at work, but will upload when i can.
R34 GT-T 4 Door
Internally stock Neo motor
Splitfire coil packs
HDi cooler w/custom piping
3" exhaust w/100cell metal cat
Tomei type A poncams
MSLR head gasket
Arp head studs
PnT Performance intake manifold w/r33 s2 throttle body
650cc Siemens Deka Injectors
Aeroflow high flow fuel rail
Turbosmart FPR800
Walbro 255lph fuel pump
Hybrid Performance top mount exhaust manifold (hopefully upgrade to a 6boost when funds allow)
Turbosmart Compgate 40
Kando TD06H 60-1 w/anti surge front housing and 10cm rear
Gizzmo IBC
Nistune
Car made 310rwkw's and 620nm of torque @ 18psi on BP98, full boost hits at 4000rpm. Since it was finished its been back on the dyno and its still pulling consistent numbers, last 3 runs if i remember correctly were 309,311 and 313 and i still get over 450kms to a tank of juice :)
One way or another I am sure you will hear how it turns out, I may not share it here given I am getting sick of making an effort sharing ACTUAL information on here to help folks out to be told that those results won't happen because this guy at the dairy's mates Auntie's boyfriend's penpal said that they don't perform.
I am definitely open minded to the fact that other housing/wheel combinations may have issues (this is actually an EVO3-16G, not a 20G) but I was told as a blanket rule by yourself and others that the anti-surge was a lemon, so far it seems not the case - will see how the final flow is but spool is already looking good. I don't know how the internal gates will perform on RB25s with bigger turbos, but as I clearly fabricated earlier... we have no spike, no drop in boost, no creep and so far tested from 10-19psi and are actually well impressed with the internal gate TD05 so far.
The IWG housing on your friends turbo is fine, thats fact. I have done one of those T25 based housings myself and confirm its the shiznit. Works a dream.
Its this T3 housing thats a bag of shite:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD06H-25G-w-T3-8cm-V-Band-Internal-gate-/281118875035?pt=AU_Car_Parts_Accessories&hash=item4173fd9d9b&_uhb=1
That housing is intended for some kind of US based car which doesnt have stellar performance from stock (so it probably works fine at low power/boost). Thats the only Kando IWG that has an issue, just to clarify. One guy even lopped the rear of it off to DIY a 5/6 bolt open outlet and it was still shite, so its probably just a dud housing for the application. The T25 one your mate is using is a copy of the MHI unit GReddy uses on their T517Z (which his turbo is an exact copy of), so it should and does work well.
Re my comments that they were a lemon; I simply gave the best advice I could at the time. More than one person had reported that their surge ported T67s weren't on par, and one guy (Dori34) had issues which were potentially but unconfirmed to be related to the 3" 20g antisurge cover. Hypergear had also reported trials of similar style surge porting resulted in similar performance set backs, so I had accepted the data as reasonable at the time. As noted I am always happy to learn something new, which I do regularly when talking to you, but just didn't want to promote something I had my doubts in.
Definitely not having a dig, you are right to raise it if you have doubts! Just be clear if they are doubts, or facts. We all do the best we have with the info we have at the time - I am just trying to make clear that there is further info which means that what people are treating as blanket rules aren't actually the case, and highlighting specific cases where that applies just in case it helps someone in the future. I think we are on the same buzz, end target is to refine a list of what ACTUALLY works it different situations and don't mind adjusting previous view points based on new information which may come to light, the mission is finding that info. My dig was actually at others who throw said info in my face, what that same kind of info should be invaluable to those it applies to.
In regards to the T517Z - interesting you mention it is the same as what my mate got (which runs the EVO 3 16G wheel) as I've seen a thread where someone reconditioned their T517Z using an EVO 3 16G as an "upgrade", but Kando treat them as the same place and other places mention the T517Z as having a 16G6 (the EVO 4+ "EVO16G" wheel, which is designed to spin the other way). Man its fun filtering through the crap sometimes!
ollolol yeah, sounds almost like an NS turbo thread. Nah its got this, nah its got that!
The E3-9 turbos all have the same 16G6, just reverse rotation on 4-9 (3 is conventional) as you noted.
Here's an official GReddy sheet that confirms the 16G6 wheel in the T517Z:
http://www.greddy.com/products/turbochargers/turbochargers-misc./filter:model:T517Z/
No worries!
In the case of the 18G I have done I honestly feel that the stock position housing could be holding it back somewhat. I have no evidence to back this up though. It made roughly 210kw with ease on a Mustang dyno. I've noticed knock here and there recently so may speak to Jez about a touch up on his current dyno.
You make me wish I'd gone a 16G6 on that car though :)
Thats a great result. I bought a TD05-18G but struck engine problems before I could get to test it back to back with the 20G. I was able to make 275rwkws om 100RON. Below is my Unite 100 tune with the Plazmaman vs the std plenum.
Be interesting to see how it goes against your graph to see how much more punchy the 18G is
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
