A combination of set figure (offset) and percentage (factor).
For a manual I estimate: flywheel(kw) = 20kw + (rwkw x 1.15)
Derived from stock figures. It's estimating it takes ~20kw to spin a gearbox at high rpm, plus you lose a percentage (15%) of gains as friction.
Seems to work well for a lot of cars, and is a hell of a lot better than straight up 25% loss claims!
ie. Stock GTST 140rwkw > 181kw flywheel
My current 230rwkw > 285kw flywheel
A random 300rwkw > 365kw flywheel
2011 Ford GS 256rwkw > 314kw flywheel, even seems to work for new automatics ;)
as people have said, it can't be a set figure. not just because of how hard the gears are meshing together. you have to remember that the more power it has the faster it is going to accelerate. the faster something accelerates the higher the forces acting against it. so while it might not be exactly a percentage it won't be a fixed figure either. there might be an exact figure of how much power it takes to turn a gearbox, drive shaft, diff, wheels, etc at a set speed, but when it comes to accelerating all that then it won't be a set number that applies to all power levels.
That looks pretty good,cant we all agree to this
But still Id think a 2000hp would quite easily lose 3-400 through driveline which is still close to 20% but once again the style of driveline would make a huge difference ,for instance a regular sedan with tailshafts compared to a car that has the engine/gearbox bolted directly to the diff..
It might show it on the dyno but there is absolutely no way it is actually losing 400hp, do you have any idea how much heat that would create? it would be enough heat to literally melt the gears if that was the case.
I think a large amount of it is how inertial dynos calculate their figures and they don't actually 'lose' the majority power that we see on a dyno, they just read less due to the way it is being measured, there are losses due to the extra weight being spun up, but they are not completely lost this way.
Edited by Rolls
That is basically the figures I have been using as well. I've always used 15% for manual, 20% for auto, then some % for age. ie, because the skyline is now 15 years old, you loose more power (compression loss, tune loss, just small bits here and there). Rebuilt/modded changes it though and brings it more closely down to the 15%, as does purely having more power (ie so the 20kw base means nothing).
I can't remember what the figures were on a rotary that was engine dyno built and then drivetrain (ie rear wheel) dyno'd, but certainly it couldn't have been even 15% otherwise the gearbox would have fried.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
    • Yeah sounds like the swirl pot isn't being fed from the return line, would be made even worse by the high flow pump.
    • This is the R32 one and the inside of the tank should look like this. which has an internal swirl pot, that the return line must empty into. (Interestingly, because the GTR tank is plastic it misses out on the swirl pot.) That is a potential cause for an aftermarket pump hanger to mess things up. Maybe the return is cut short and squirting over the side.
