Hey all,
I purchased my r32 only like a month or 2 ago.
The car feels very slow/sluggish until boost kicks in.
I get munched by little yaris/jazz/swifts etc... at the lights (just driving normally)
Boost on car does not kick in until atleast 4-4.5k!
Car has fair bit of work done to it.
CAI
Pod
FMIC
3" TBE
Pon cams
Cam gears
Bigger injectors
Better coilpacks
Z32 AFM
Upgraded fuel pump
Bigger turbo
Nistune ecu (can't remember if that's the correct name)
Few other bits.
I hardly ever floor/race my car as turbo lags and it drinks so much petrol... i'm a GRANNY driver! LOL.
However when i drive normally it's so slow/sluggish... all these cars just overtake me and the ones driving behind me get's frustrated that i'm so slow.
Car does not feel like a straight 6 down low in the rev unless turbo kicks in. Getting overtaken and beaten by 1.3L is a disgrace!
Is this normal or what's up with the car?
Any advice/help would be great.
Thanks guys.
Edited by starscream_r32
Sounds like you have a bad case of rb20, only way to fix it is with some extra capacity.
Also didnt you test drive this vehicle before driving it? Even if you were just riding passneger it should have been fairly obvious what sought of power you were getting.
Find out exactly the specs of the cams are, as they don't add power, but shift the power up higher in the revs which is why you are seeing no low to mid-end power, great for track driving... not so for daily driving. You could dial in the adj. gears to help bring the turbos on earlier but need a dyno to confirm the changes.
lol.. guys i'm talking about racing off the line!
i'm saying normal driving/take off it's slow/sluggish unless i put the foot down and get it into the turbo boost band.
should still have some umphh even without the turbo kicking in? Its' an inline 6! feels slower then a 4cylinder. loll.
Turbo is hypergear 28?
Yes car is tuned.. (probs needs a retune) but it is tuned with current mods. about 235rwkw on dyno sheets.
its an RB20... has no VCT
There not that punchy off boost, but they do rev nice, most of the power is when the turbo comes in, and without the VCT you dont feel the torque like you do with a RB25
Please show a photo of this turbo or the person whom you've got it from, I will be able to give you some specifications of it if it is one of ours. Also check the wastegate actuator adjustment. Make sure its tightly shut.
A healthy RB20det should still be pretty ok down low even without VCT. I would check cam timing and have a play with cam gear settings.
u sure it doesnt have a dirty big set of 280 cam and some poorly matched or hybrid turbo?
cam and turbo selection can quiet easily make it feel like a bucket of shit down low
type in www.google.com and search RB20 lag...
Do some research on what parts you already have prior to running to a tuner. many will pick up you haven't got a clue and wrought you..
RB20's do not have low down torque. dont expect much until it comes on boost or at least is well above 3krpm.
RB20s are crap off boost. think of it like this, a 2 litre towing a 1300kg car, slow... 235rwkw from a 20 makes me think it would be really laggy which would then make the painful wait for boost even longer! i know mine is painful but my boost starts at just over 2000rpm (stock turbo lol)
having said that i don't know what difference cams and some of the other mods would make, mine only makes just over 160rwkw
haha what you expect? To drive around below 2000rpm? This aint a V8. The engine was designed to rev out. Hell, the redline is 7700rpm afterall. If you are after more response, sell off the turbo and replace with a HKS2530. Comes on boost at 3800rpm~ and will give you max power of 210kw~ Else, live with it and rev out to 4000-5000rpm between shifts.
My r32 has an average fuel economy of 11.5Ltrs/100km~ Work out if yours is similar.
if you take the car on the track, you wont be seeing under 4000rpm anyways, so decide what the plan with the car is and start to change whatever you dont like.
i rarely got past 3k.
so ur saying if i keep all gear changes under 3k without kicking the turbo in then from stat to finish ill always be slower/behind other cars?
even lilttle 1.3,1.5L etcc are faster/ahead of me?
dunnoo. if u guys get what i'm talking about but yer... maybe u needa be in the car to understand..
everyone that sits in my car thinks its slow cos i keep it under 3k and not let the turbo kick in... but boy do they get a surprise when i rev it though..
lollll..
i'll get a retune and fix a few little stuff and see how i go..
turbo cars are designed to go fast when boosted. Simple as that.
non turbo cars have the advantage of no lag, and I think your forgetting that some little cars, even with there small 1.4L engines etc, are still quite light and if there putting there foot flat to the floor, the engine will be at its peak performance, where as your RB20 at say 1/4 throttle, off boost will be no where near its potential.
your saying we arent getting it? is there a better way you can explain it if the above is not how your driving it?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
