anyone know where to start looking..
gettin bad compressor surge in 3rd gear full throttle running 20psi, happens really bad if im doing 60kmph in a higher gear..and put my foot down.
wont surge in 1st or 2nd ..
only really started doing it recently..
4" intake with 4" filter thats only 6months old?
any ideas?
https://www.sau.com.au/forums/topic/348357-gt3582r-compressor-surge/
a stock 2.5ltr is gonna have a hard time ingesting that much air IMO.
Most people using a GT35 either have a 25/30 or a 25 head thats been tidy'd up a bit and so on.
BOV setup and so i assume is all functional?
I don't run a bov
but i could test out a bov which i have lying around here.
Its just weird that its only started doing it recently.
infact it could have been happening earlier its only since i got the external gate plumbed back into my exhaust that i can actually hear the motor etc..
ah... key information you missed.
there is no way, under load in 4th, the gate will be opening.
so external or not, you should quite easily be able to work that out.
either way you might need a GTR BOV that leaks low throttle, it might alleviate.
otherwise it could also be in the tune which is another point.
My GT3040/600HP had ever so slight surge at around 2200-2400rpm from memory. barely audible at the best of times and didn't hurt the graph majority. Only did it in 5th as well so wasn't much of an issue. the larger comp wheel in the 35 will just make it more noticeable over mine.
Yes you prob are right i dont think gate opens until around 16psi.. so i should have heard it.
well the bov i have here is just a blitz bov and the spring is soft, but i was using this bov 2 weeks ago when i was out and about one night and thats when i first picked up on the surge ..
might pull intercooler off and give it a clean could be restricted ? oil residue?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
