what hoses did you use. same again with the vq35?
Yeah, but G35/350Z are the same.
I used the Mishi silicon kit - http://www.conceptzperformance.com/Cart/description.php?II=5319&Car_Type=G35&UID=20121225212428182.239.175.146
Kit is good. Had to cut up the top hose to fit the temp sender I'm using for the thermo fan controller, and the hose from the overflow bottle to the neck of the radiator is a little long.
If you're going to do it grab some emery paper too just to clear off any corrosion. I'll do a write up soon but I didn't get many pics this time.
can someone confirm that would this fit on the vq25 at all. http://www.ebay.com....=item4cf97b023a
Don't think so. Our fuel system has a return, which I'm pretty sure the VQ35 doesn't have.
You won't need to upgrade the fuel rail for a while though, plenty of time. I think Scotty is still using stock rail just twin Walbros and larger fuel hose?
thanks for the info ryan. Good to have great knowledge on topic as you have just done your cooling system as its next on my list after dump install and 3 inch exhaust.
No worries. If you're going to do the radiator I'd suggest deciding now if you want air conditioning or not. Because no air con will save you a lot of hassles :P
I may have found the cause of my boost spiking.
Twice now I've found the drivers side hose that connects the plenum to the standard fuel reg disconnected, and another hose loose.
I've cable tied the hose for now, guess I'd need to replace it eventually.
Actuator in. Would have been a 5 minute job if someone at Nissan had given us an extra inch of space around the actuator. I can see it'd be a nightmare job if you still had the stock intake, but Andrew at AM Performance designs all his stuff to work around bolts where possible.
Looks like the boost controller needs an adjustment so that it knows the new actuators default is 15PSI.
I'll give it a decent drive tonight and try and get that actuator into the mail tomorrow for you Scotty.
Just bypass the boost controller solenoid for now, and let me know what boost it's running without bleeding air off. Plumb it back in before the dyno, but don't drive it hard before tuning it mate, it will run much more boost up high in the revs...
I haven't got a boost gauge - well, I have the stock boost gauge, but it needs soldering up again and I don't think it goes high enough.
Just took it for a short drive after resetting the boost controller to min 15PSI, and dialling the max down slightly to 16.5PSI.
I'm not sure if it's boost spiking, or creeping, or wtf it's doing, but the EVC is reading boost hitting a peak of 20PSI - no higher.
Staring to wonder if it's a plumbing issue. Trying to work out what I changed between everything working, and it first getting tuned. Only changes I can think of were the MAP sensor being tapped into the hose going to the top of the BOV, and fixing up the hose to the stock boost sensor, which had the EVC tapped into it. Everything else is the same.
Yeah kinda wishing i bought ironpaws set not too long ago. Ah well
I've got a spare from when I smashed one. Send me a PM or grab a set of 100mm Narva spotties and mod them to fit. That's what I did.
quick question guys, previously i have gotten mechanics to do the oil changes on my car as its been in there anyway but i'm gonna do this one by myself. What i would like to know is where to get the crush washer for the sump plug from. Will they have a suitable one at supercheap or is it a genuine nissan design that only they sell at rediculous prices??
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
