Just picked up a cargo net from slippylotion.
Really thrilled to go to fit it and find that Northshore have put the child anchor points in line with the rear cargo net mount :domokun:
Dunno whether to call Ben and tell him (at least they won't do it to anyone elses), remove them or just not worry about it.
Look nice Jase and I see you went with KU31's.
What size rims did you get?
Yeah ended up going with them in the end after you were talking about the wheel bearing. From all accounts they seem to be a good value to performance trade off. If they are noisy I'll just have to deal with it.
Ended up going for 19x9.5+20 after speaking with Chris (spoolin12). Seems like pretty safe fitment - any further and it's hassles.
Ryan, those mounts should be in the same position as mine, they should all be fitted in regs with the evidence pack from RAWS.
I'll check it again in the light of day, because the pole didn't seem to be telescoping right either.
That's the idea to be honest. I love Japanese cars but our good friends in the police force don't, so I'm trying to make this car look as tough as I can without attention from the boys in blue. Euro all the way. :thumbsup:
I like em... Varrstoen make a wheel like those.
What make are they?
What tyre size did you go with?
Edited by impul535w
What make are they?
Avants. Tricky to get though.. I saw the Varrstoens but they weren't concave enough for my liking. Or the other ones had the dish which wasn't for me.
There are a few others. Monotec I think they are called. And then Aluflugens I think.
As per spoolin's recommendation, 245/40's. I think from memory 265/35 would have been ideal rolling diameter but maybe lacked the minimal amount of stretch that mine have (really it is barely noticeable, you have to look hard to see it)
Got a spare key coded this morning. Mine is keyless entry/start - so cannot be programmed with the lock door procedure. Hornsby Nissan did it - $178.60 for the remote (without emergency key, as its not needed) and $134 for the code (about 1hr labour charge I think)
So, spare key - $312.60, pretty good I think.
top work on the spare key. on a side note PN-Mad is looking for a donar kidney as his last one just went to nissan.
Edited by joshm35
Lol... yeah- thats going to be cheap compared to what I'm going to fork out over the next few months!
Need a spare key really- I have heard some horror stories about the cost of keys, up to $800! Its blatant rip offs I think. Plus, tow truck from teh edge of bum f nowhere would be far more painful!
If only it was as simple as the door lock coding thing! Trust me, I tried it, before I contacted Chris Rodgers. Your pretty much stuffed if you don't have the Nissan system.
After seeing slippy's wheels tonight I think I'm going to go that way... 18x9 +30s, right?
Perfect stance to me with those 45 profile tyres! :thumbsup:
Yep, thats the sizes. Im happy with them and the look.
How did you go with the cargo net fitting?
Hey Paul,
Has the cargo barrier already been sold? I spoke to vince today and all good.
Or you have two?
If not big kev, send me some pics after your install if pos. Love to work out how to install it....
All good there is two for sale. Bigkevracer bought one and you for the second one.
Send me your number and I'll send you pics of it installed.
Edited by slippylotion
http://www.skylinesaustralia.com/forums/topic/376446-sa-s1-c34-cargo-net-frontrear-swaybars/page__gopid__6040082#entry6040082
I need to sell my C34 cargo barrier net. Never used it in 75-odd months Ive owned the Stagea.
Nothing new with my stagea - have no idea when the bottom end will be ready & engine reinstalled. :(
Been studying some text books ready for Med.Science next year at Uni; mind is currently full of bodypart names (anatomy)
Hitting up the Beta for Battlefield 3 for study breaks..... awesome game.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
